Hard time finding Main Bearings for my 3.0
I'm ready to finish my 3.0 rebuild, and I'm having a problem locating quality main bearings to assemble my engine for my 82 Targa. It seems that Pelicans only option is Glyco. I tried several dealers and its a special order from Germany with the total cost running around $1400 and a few weeks wait.
I did not anticipate this. I hear Glyco horror stories of inconsistencies.
I figure I can't be the only person having this problem, and am wondering what other people are doing for air cooled bearing sets.
Old 02-22-2017, 12:51 PM
Try not, Do or Do not
Henry Schmidt's Avatar
We have options for main and rod bearings.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-22-2017, 01:07 PM
Under the radar
Trackrash's Avatar
I don't want to start another Glyco thread but....
Porsche uses Glyco, but they check them?
It was a problem with some of the 3,2 rod bearings, not the 3,0 mains?
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-22-2017, 01:12 PM
txhokie4life's Avatar
I measured my glycol main bearings and found several out of spec. I sent them off to Calico to get them spray coated and now they are about perfect.
Old 02-22-2017, 09:14 PM
The process of coating a bearing with dry film can only change the bearing measurements if the babbit (white metal coating) on the bearing is applied inconsistently.
During the process the bearing is blasted with low pressure using aluminum oxide media. The bearing is then cleaned, dried and sprayed with the product of choice.
Some products are then air dried, heat light dried or oven cured.
The dry film coats the bearing with .00005" to .0001" of product. Depending on the provider, the dry film is then processed. The product manufacturer generally provides a method of burnishing or light oil coating.
Henry Schmidt
Ph: 760-728-3062
Old 02-23-2017, 07:13 AM
