Super Moderator
cstreit's Avatar
How far does flywheel seal protrude?
Well we put the cases together but I'm wondering if the flywheel seal made it in all the way. It appears to protrude about 1-2mm past the edge of the case in that area.
Are they supposed to? Or should it be flush?
THere's still 1/2" inside the case, do I need to remove and re-install?
THanks,
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-11-2003, 08:45 PM
Super Moderator
cstreit's Avatar
Whaddya think, should I pull it out and install my extra one?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 01-12-2003, 05:23 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Sorry if I am asking a dumm question here:
From what I understand you can replace this seal with the case together. So if yours protrudes, why can't you just drive it in further until it is flush?
I want to replace the flywheel seal on my 3.6 before I put on the flywheel and ready it for my conversion.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 01-12-2003, 10:57 PM
Super Moderator
cstreit's Avatar
Wayne,
I tried that actually...
Tapped it. THUMPED IT... Then took a good whack at it (with a rubber mallet...
It doesn't move at all!
I think the Curil-T around the perimeter is preventing it...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 01-13-2003, 06:02 AM
Somewhere in the Midwest
MotoSook's Avatar
Chris,
I think the way that seal is seated, it is probably providing a better seal then if you were to install it with the case together. Besides if the seal leaks, you'll have a crew waiting to replace it
Old 01-14-2003, 12:41 PM
Rick Lee's Avatar
I put a little goop on the seal and then tapped it in lightly with a block of wood laid across it. Once it's almost flush, use something round and about the same diameter to get it all the way. I can't remeber what I used, but I went through one seal before I got it right.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 01-14-2003, 01:14 PM
Super Moderator
cstreit's Avatar
Well see, that's the thing... It won't move at all. I tried tapping it in with wood... It won't go in any further...
My choice is to horse it out, or to leave it in and see if it works...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 01-14-2003, 01:41 PM
Rick Lee's Avatar
Either way you're playing with fire. Spend $18 on a new one, rip the old one out and put the new one in the right way. Ask yourself if saving $18 is worth a potentially huge oil leak at the flywheel and another engine R&R.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 01-14-2003, 01:57 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Got the tool............
Chris,
I have the fancy-schmansy installation tool if you'd like to use it.
Works really good.
Works so good, I installed my new seal a CH too deep.
I also have the pulley side too too.
Kevin
Kevin L
'86 Carrera "Larry"
Old 01-16-2003, 12:04 PM
