98mm Nickies
Has anyone used a 98mm bore 'Nickie' in a 3.0SC motor?
I believe that there is a slip fit cylinder that avoids having to machine the spigot in the engine case. Has anyone tried them and is the spigot on the cylinder strong enough? Thanks
Kartoffelkopf
Hi Chris, I'm using their 98mm cylinders but in my Turbo, as you know. If they're the same part as you'd use for the SC, I'm happy to snap some pics before I send them back to Chris for reworking? (Cleaning them up before packaging, as I type)
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
Under the radar
The 95mm SC and Carrera cylinders are commonly bored to 98mm so would be slip-ins.
We just bought a set of these for our 3.0 build. I will start a thread when I get the case and other internals back from machine shop
Thanks,
It seems as of the spigot strength of the slip-fit cylinder is OK an my slight concern is unfounded. |
Try not, Do or Do not
The 98 mm Nickies can be purchased in both configurations. For my money, either configuration is a better choice than slip-in Mahle. They have proven to be stronger.
I've used both. The issue is, how well will the cylinders stay round? Slip-ins handle cylinder pressure with no issues but are less likely to be round after prolonged use. In an NA engine, we have seen few issues other than ovality. In a high performance turbo, I prefer the stability of the thicker (bore-in) cylinders. Different cylinder, same issue, the 100mm Mahle slip-in cylinder has proven to be a poor choice in almost every application. The cylinders fail miserably when in comes to staying round and we've even seen cracked cylinders at the base gasket line. They are just way too thin there. With Nickies, once again, no issues with breaking but slip-ins are less likely to stay round.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
hmm...that kinda makes me wonder if I should return the slip ins and have them send me a bore in set
case is still bare and at the machinist |
I might be able to buy a used set for my 964 3.6. |
The thick-walled, 109mm RSR ones are just fine.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Are the Nickies slip-ons?!
Thanks!
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
I was going to purchase bored and plated Carrera cylinder(to 98) to make my 3.0 l a ss 3.2. Is this a good choice vs 98 mm nickies based on the above statements?
So why do they not stay round?
What forces are being applied to the spigots to make them deform? We have made cast iron wet liner cylinders for Coventry Climax engines for years and these have a spigot wall thickness of less than 2mm and never seem to move. Would a JB Racing steel cylinder be a better option? |
Chain fence eating turbo
Chris, if you don't know, how would we?! HAHA
Seriously, isn't it due to cylinders not being round on the OD and cooling/airflow differences across them? |
The slip in 98 work just fine but like anything else could be better. One thing that we have discovered is that "re-plating" or coating with Nikasil can be performed on K&S cylinders (Alusil). The material used (Silikite "SP") seems to be a more stable cylinder (lower expansion rates) and as such make for a better candidate for Nikasil coating. Much better? who knows but it seems from our experience to be noticeable in the long run.
JB Racing makes a very nice product but it is just a Biral cylinder. (aluminum fins over a cast iron sleeve. When we use Biral cylinders, we like to coat the cast iron liner with Nikasil. This does three things: It guarantees more consistent cylinder ovality (we have great faith in Millennium Tech. quality control) Gives us a longer life expectancy Allows us to run a "better" quality ring pack. Note: coating a used Biral cylinder (Mahle) with Nikasil can also bring a used cylinder into spec for concourse restorations.
I would never argue with measurements but I am interested to try to understand what is happening.
Is it the spigot that becomes oval or the complete cylinder? Does the depth of the fins change with the diameter of the spigot? If you use a Nikasil coating on the cast iron do you use the same oil control ring tension as on the aluminium cylinder? When we press out the ductile iron cylinders we use on the Climax engines - which we Loctite into place - they never seem to have moved and the Aluminium deck is always good enough to accept a new liner. |
We built a track 3.5 with LN "Nickies" 4.5 year ago. It is back for a refresh. We should have it pulled apart next week and will measure for ovality. These were 100mm slip ins...
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
hi
regarding a 3.0 SC engine with 10.5 piston what kind of improvement (hp) can I expect using a 98mm bore so 3.2 SS engine ? thanks |
I agree with Henry about using replated cylinders.I have to wonder if the ovality problems people have might be related to residual stresses in new castings since in my experience it's less of a problem with "seasoned"-replated cylinders. I'm damn sure heads warp-so why not cylinders too.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
