Disappointing dyno results?
Hi!
Just finished rebuilding my 2.7 litre CIS. 40 mm carb conversion, S cams, larger valves, lightened flywheel, high comp pistons from Wössner, etc. Single plug. Reached 198-205 BHP at the dyno test, but was expecting more. Anyone who has experience from a similar spec and mind sharing your results?
Thanks!
Old 01-10-2017, 05:19 AM
Should probably add that I have racing headers and a sport exhaust. Ie nothing that should really hold back performance.
Old 01-10-2017, 06:54 AM
Chain fence eating turbo
You getting full throttle?
Old 01-10-2017, 07:06 AM
Air fuel ratio good? Need to be in the 12's for max power. Leaner or richer will lose power.
Old 01-10-2017, 07:07 AM
Timing fully advanced? Weights moving freely? Dizzy slop?
Old 01-10-2017, 07:08 AM
I am having the engine built abroad, so I cant say for sure. But I assume the carbs are set properly. If not, what can be the BHP difference between poorly and correctly set carbs? Possible to say?
Old 01-10-2017, 07:15 AM
Impossible to say. Be a little or a lot.
Old 01-10-2017, 07:49 AM
Originally Posted by RSSweden View Post
Hi!
Thanks!
205bhp was reached at the wheels or flywheel?
Big question: What were your intake and exhaust ports enlarged to?
An engine such as you describe, if say 36mm intake ports were used, should be good for at least 220-230bhp. As a reminder, a 2.7mfi motor uses 36mm ports and I am told often make in mid 220s at the flywheel despite being factory rated as 210. Your engine should produce similar results as it is not very different.
Please let us know the port size
No physical quantity completely explains its own existence
Old 01-10-2017, 08:30 AM
If the carb jetting and ignition timing is not optimal then you could easily leave 5-10% of the power on the table. The difference between running overly lean or too rich can be significant
Old 01-10-2017, 08:32 AM
205 at the flywheel. I am not entirely sure of the port sizes other than that they are larger than stock. Should know this of course...
Anyway, regardless of port size it certainly sounds as if the output should be 10-20% higher. Might be that the carbs are set to comply with CO emission standards, but that should be easily adjusted.
Many thanks for confirming my suspicion that it is too low and that I need to dig deeper into why performance is off!
Cheers!
Old 01-10-2017, 10:44 AM
JmuRiz's Avatar
Is the engine being built/dyno'd in Colorado?
If so, that makes a big difference due to altitude.
'73 2.0 914 (2.8 /6 conversion in progress)
'64 356SC
'65 Ducati Falcon 80
‘19 Audi SQ5
Old 01-10-2017, 11:15 AM
It's built at sea level in Europe, so altitude is not an issue.
Old 01-10-2017, 11:18 AM
clutch-monkey's Avatar
dyno'd there as well? dyno's outside the US tend to read lower for a variety of reasons, if the engine feels healthy to drive and the AFR etc are all good i wouldn't worry about it.
could also be a ball breaker of a dyno in general, on top of that.
Old 01-10-2017, 12:46 PM
Port sizes known yet?
Old 01-10-2017, 12:58 PM
Member 911 Anonymous
DRACO A5OG's Avatar
For Street or Track use?
If Track use straight bugle type pipes, I observed a dyno set and they swapped 2 in 2 out with SSI headers vs Bugle Type, made a quite a difference in HPs. But loud as Heck.
'85 Carrera Targa
PCA/POC
Old 01-10-2017, 01:10 PM
When you say "S" cams do you mean CIS S cams or real S cams like on a 68-73 911S?
Old 01-10-2017, 09:25 PM
