3.0 head question
Rebuilding my 3.0
What is the best way to get rid & plug of the air tubes in the exhaust port?
Old 01-25-2017, 07:32 PM
Use a fine thread 10mm bolt from a hardware store
Bruce
Old 01-26-2017, 04:29 AM
10mmx1.0 thread (I've found this to be hard to find off a shelf) , or a 1/8NPT pipe plug will work as well.
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 01-26-2017, 08:55 AM
abit off center
cgarr's Avatar
I have used set screws, mcmaster carr has them part #99642a154 10x1.0 10mm long
______________________
Craig
G2Performance
Old 01-26-2017, 11:25 AM
Tks cgar
Do you seal the threads in any way?
Old 01-26-2017, 12:44 PM
abit off center
cgarr's Avatar
As I remember they tighten up in the hole but some high temp loctite wouldn't hurt
Craig
G2Performance
Old 01-26-2017, 12:53 PM
Walt Fricke's Avatar
Since the 1/8th NPT thread is not an exact match, I think using those plugs will distort the threads enough that they are not apt to come out again . Since it is likely you'll never need or want to pull these plugs, you don't have to worry about distorting the threads in the head as you keep screwing the plug in with more and more force. But I've always used the 10x1.0 stuff - it bottoms, and doesn't get in the way if something sticks out some. The set screws look a bit better in this application, though.
Old 01-28-2017, 10:16 PM
Walt
i don't think the thread is NP.
Looks like straight thread
Old 01-29-2017, 01:49 PM
It is straight thread, M10x1.0. I used a 1/8NPT for one head that had some thread damage and ejected a M10x1.0 plug. NPT worked like a charm and haven't had an issue since.
-Jayson
IG: Signature_911
Old 01-29-2017, 06:36 PM
Er, I thought I said it was straight thread, not NPT. '76 put his finger on when using NPT might be useful - when the metric threads are buggered. The NPT might hold, as it just sort of cuts some of its own thread (worked for '76). Which would be fine if the threads are already bad. And even if it doesn't work, well you can just drill and tap for M12? Or for a thread insert to get back to M10 fine. But typically there is no reason to remove these plugs unless you are going to put the anti-smog air injection back on.
Some Loctite red isn't a bad idea either, though this area gets quite hot.
Old 02-10-2017, 07:11 PM
prschmn's Avatar
I've used 1/8 NPT set screws often without issues. Set it a bit below the surface and then stake them with a punch and they'll never give you a problem.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 02-11-2017, 06:25 AM
Pelican used to list a part in their catalog. It is actually a 914 brake plug.
Part #: 914-352-000-00-SIC
Old 02-13-2017, 12:41 PM
