Locking SC Distributor for 930?
I have a 1976 930 that I want to lock the distributor on. I was wondering if I could use an early 911 SC 3.0L distributor instead of my original distributor since the distributor curve would not come into play as it would be locked down. I live in CA and need to smog every two years so I would want to just swap the distributors for smog when necessary. Aside from locking down the distributor I would need to change the drive gear as the early 930 have a CW rotation.
Would this work?
Thanks,
Rahl
Old 01-26-2017, 09:25 PM
Rahl,
The SC distributor will not work since it rotates CCW and yours is CW.
The Carrera 3.0 rotates CW and would be a candidate for what you are proposing. Make sure you allow for rotor phasing if you lock the advance out.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-26-2017, 10:55 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Another option might be converting a 3.2 Carrera distributor.
It rotates the correct direction and all you need to drive it is the correct drive gear. Early 2.0-2.7 gear.
Adding the electronics is a little challenging but it can be done.
If you're looking to lock the advance you might simply install a Pertromix unit or something similar.
As for your smog issue, send me an email and I might be able to help you with that.....legally of course.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-27-2017, 07:56 AM
Thanks Steve! So you can not just run a distributor backwards? CW vs CCW?
Rahl
Old 01-27-2017, 08:20 AM
Thanks Henry!
I sent you an e-mail.
Rahl
Old 01-27-2017, 08:21 AM
Rahl
Yessir, thats correct.
Henry may have a good solution for you.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 01-27-2017, 06:56 PM
Thanks Steve! I will see what Henry has to say.
Rahl
Old 01-27-2017, 07:08 PM
Rotor phasing ?
Steve,
I'm working on the same issue as Rahl. Can you elaborate on rotor phasing?
Old 02-17-2017, 01:00 PM
It's a 914 ...
stownsen914's Avatar
I have a similar question about the CCW vs. CW distributor. Is it possible to modify a CCW distributor to make it work CW?
Old 03-04-2017, 05:55 AM
"Can you elaborate on rotor phasing? "
When a dizzy is locked it has to be in a position so the rotor to tower terminal distance is such that at full advance the rotor won't fire to the previous tower (#5 on these when setting for #1) It depends on how much advance, diameter of dizzy cap and width of the rotor and tower terminals. These engines have a small dizzy diameter but a wide rotor terminal. On other engines they make larger diameter caps and adjustable rotors to get the right phasing.
Old 03-04-2017, 07:05 AM
Anything is possible but it's not a practical option.
Henry Schmidt
Ph: 760-728-3062
Old 03-04-2017, 07:15 AM
