BobnJoz
Send a message via AIM to bobswei
Where did I pull this wire from?
I posted this on the tech forum with no luck. I'm rebuilding my '72 2.4T and I'm at the point that I'm finishing up last details. But, I can't recall where I got this from? I'm sure it's in the coil/dizzy area, I think. It's around 12" long. There is a similar wire that grounds to the chain box housing, already there. From where to where?
Here's the wire on a '70 E that I used to have. Any ideas?
Old 01-30-2017, 07:58 PM
My '87 has one like that and it grounds the aluminum rear relay panel that is mounted in rubber mounts. It goes from a 6mm factory ground stud nearby the CDI box to the relay panel.
Old 01-30-2017, 08:41 PM
BobnJoz
Yea, JFairman. I think your right. Someone on the tech forum also mentioned that and it seems like there was a braided wire there. That's where I will install it.
Thanks!!
Old 01-31-2017, 07:17 PM
Cool. I think one end of it goes under one of the screws that holds the CD box to the relay panel.
Old 01-31-2017, 07:35 PM
