resurface 930 cylinder heads
Hello,
I tried another company for resurfacing a set of 930 3,3 cylinderheads. I wasn´t attented when I picked them up, but today when I start assembling the engine I saw that they only cut the inside, but not the outer head surface. I checked with a feeler gauge and there is no play. I used new cylinders and they are 2.7 mm. The high difference in the head is 2.7 till 2.85. poor job, I will for sure not use them again. But what are the numbers I should have? Sorry for my poor english. Attached is a picture. I hope that makes it easyer to understand me. The blue numbers are the high differences. And this is where I need the original porsche numbers. I cannot find them in any of my book...
Many thanks in advance, Malte
Old 02-03-2017, 10:24 AM
abit off center
cgarr's Avatar
They didn't go the full .25mm it looks like. The original surface should be 84.50mm. Those could be cut again and cleaned up, just adjust with a .50mm base gasket or what ever it takes. And yes the outer surface should have been cut the same amount or it can hit the cylinder fins.
Min would be 84.25mm
______________________
Craig
G2Performance
Old 02-03-2017, 11:57 AM
Thank you! I am pretty sure they just cut till the surface looked good and didn t kept any eye about how much they cut them. Do you know the factoy difference between the inner and the outer surface?
Old 02-03-2017, 12:10 PM
abit off center
cgarr's Avatar
Every one I have measured is 2.50mm
Craig
G2Performance
Old 02-03-2017, 12:15 PM
Thank you very much!!!
Old 02-03-2017, 12:57 PM
Member 911 Anonymous
DRACO A5OG's Avatar
a Plug for Master CGarr,
My heads masterfully done by him:
Relax, have a CGarr, Head Machine/Rebuild Service Review
Most importantly, properly marked for future reference.
'85 Carrera Targa
PCA/POC
Old 02-03-2017, 07:43 PM
Great job!!! But a little far away from germany...
Old 02-04-2017, 12:47 AM
Germany
Where in Germany are you located ?
Best reg.
Dirk
https://www.facebook.com/edelweissmotorsport/
Old 02-04-2017, 02:27 AM
Forced Induction Junkie
WERK I's Avatar
Craig,
Would that same 2.50mm rule of thumb apply to the C2 Turbo heads that use a head gasket?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-04-2017, 04:42 PM
Dirk, I ´ll give you a call this week.
Thanks, Malte
Old 02-05-2017, 11:15 PM
I had very good experiences with weil-motorentechnik.de
Give him a call. He is very knowledgeable and friendly.
Good luck,
Alex
Old 02-06-2017, 08:34 AM
