Mike the mechanic's Avatar
white valve seals
Great new forum!!
Can anyone tell me the difference between the white valve seals and the regular brown/gray ones?
Thanks!
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 01-17-2003, 04:45 PM
Irrationally exuberant
ChrisBennet's Avatar
The Viton ones are brown/grey ones. The white ones are Teflon.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-17-2003, 04:51 PM
Senior Member
Doug Zielke's Avatar
FWIW.....
The expert machinist who re & re'd my 3.0 cylinder heads, advised *not* to use the white Teflon seals. He installed the brown seals as supplied in the OE gasket kit.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 01-17-2003, 06:42 PM
Senior Member
Originally posted by Wayne at Pelican Parts
Hmm, I haven't heard that these *ever* leak. Either one should be fine...
-Wayne
The white ones *don't* leak. That's the problem.
The OE seals are designed to allow a specific amount of oil past the seal to lubricate the guide and valve stem.
(This, from a specialist with over 20 years of cylinder head rebuilding experience.)
Old 01-18-2003, 06:33 AM
My "head guy" says he sees accelerated valve stem wear from the Teflon seals. Steve Weiner advises using the Viton ones except for the exaust valves on Turbos.
-Chris
Old 01-18-2003, 10:17 AM
Alot of good info here! So Chris, what does Steve reccomend for the exhaust valves on turbos?
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 01-18-2003, 02:41 PM
Oh sorry, he recommends the Teflon for the Turbo exhaust valves.
-Chris
Old 01-18-2003, 04:22 PM
Just curious as to why it would be recommended to use the Teflon on the Turbo exhaust side. Possibly heat related...
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 02-11-2003, 01:15 PM
The material used for valve stem seals has varied from rubber,
to Teflon, to silicone, and finally to Viton to achieve the
best oil control, heat tolerance, and longest life. These
Viton guide seals, while more expensive than their
predecessors, do an excellent job of keeping oil consumption
to a minimum. We have installed a LOT of these guide seals and
so far, not one given any troubles. Same for our phosphorus
bronze guides. When installed and used properly, end of
problems (at least with these). We only use Teflon on the
exhaust guides on Turbos due to the major heat stresses that
these engines place on exhaust valves and the additional oil
that Teflon seals allow down the guides helps lubricate an
item that sees temperatures over 1400 degrees. 935's had
special drillings in the heads and guides to do similar
things.
Use Viton seals in confidence with any naturally aspirated 911
engine!
Old 02-11-2003, 01:39 PM
Navin Johnson
TimT's Avatar
OK a heads up:
The Viton seals are fine, they really wont leak until the valve guides are way worn, nor do the teflon guides.
The are some issues with Viton valve guides though. The Viton o-ring come mounted in a bakelite "cap" that fits over the valve guide.
I have seen a set of heads come back from being rebuilt where almost every bakelite viton holder was fractured by poor instalation.. That engine blew smoke. We didnt see the problem with the valve seals until we broke the engine down on our dime.
The teflon seals are much easier and forgiving to install.
'69 911 GT-5
'75 914 GT-3
and others
Old 02-12-2003, 07:41 PM
tbitz's Avatar
Can the intake valve seals be replaced with the engine in the car with the intake runners removed?
It looks like I have a leak. Check out this thread for pictures:
http://forums.pelicanparts.com/porsche-911-technical-forum/99187-oil-leaking-intake-valve-seat-serious-post701392.html#post701392
Tony
'78 911SC with BITZRACING EFI conversion kit
Old 02-22-2003, 09:22 AM
Senior Member
I had EBS redo my heads and they came back to me with the teflon seals installed. I also purchased a gasket kit from them that came with the other seals.
I left the teflon ones in there. Should this be something I try to replace or leave it well enough alone
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 02-28-2003, 01:10 PM
kwikt 911's Avatar
I had my heads done by Ollie's and they too installed the teflon seals. Hmmmmmm!
Kevin
72 911T/E
Old 02-28-2003, 06:55 PM
Senior Member
Any one know the answer to this
I left the teflon ones in there. Should this be something I try to replace or leave it well enough alone<<
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 03-07-2003, 02:06 PM
Navin Johnson
TimT's Avatar
Im not sure what the question is.... I havent seen a gasket kit that comes with teflon seal, every one I have bought has the viton seals.
For some time the recommended valve seals have been the teflon ones.
I have bought gasket kits, and not used the included viton seals, and have bought the teflon seals to use..
Both types of seals work....
'69 911 GT-5
'75 914 GT-3
and others
Old 03-07-2003, 06:13 PM
The guy who does my heads (all he does are heads) recommends the Viton.
-Chris
Old 03-07-2003, 07:48 PM
Navin Johnson
TimT's Avatar
Has anyone read the new excellence?
Its back to viton... after years of pushing the teflon seals its back to the rubber ones....... go figure....
'69 911 GT-5
'75 914 GT-3
and others
Old 03-09-2003, 07:35 PM
For me the issue is longevity under all conditions and that's where teflon wins. Additionally, I seem to remember that the Viton seals were suspect in starving the guides for oil especially in the Carrera series. Properly installed teflon seals allow sufficient oil to lubricate the guides. If I'm off base here please let me know.
Old 03-09-2003, 10:10 PM
