What dizzy for my build?
I am building a 2.4 with 2.2 s pistons, Solex cams, and webers. I currently have a 0 231 159 006 Dizzy that looks to be for a 2.2 E.. I am looking for some feedback as to if this would be an acceptable Distributor for my needs or if it needs to be recurved?
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 04-11-2017, 05:22 AM
Sigurd's Avatar
I do not know if this is available from our host:
123Ignitionusa, LLC - Search Results for "Porsche 911"
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 04-18-2017, 01:57 AM
3 restos WIP = psycho
kenikh's Avatar
E dizzy curve should be fine. That's a lot of compression for single plug, though.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-23-2017, 08:11 PM
Plays with cars's Avatar
I'd grab one out of a 2.4l motor instead of a 2.2l. The 2.4 has a slower advance rate which would be good for higher compression and single plug. The T, E and S have different distributor part numbers but the curves are the same; the only difference is the rev limit set point on the rotor (which is replaceable and interchangeable). Save yourself some money and buy one for a 'T'.
I built a similar motor (2.4, E cams, 2.2S pistons, single plug) and am using the 2.4l advance curve with good results. (butt dyno results only)
Mark B
'73 911S (long term ownership) '70 914-6 (long term project) '74 914-2.0 (sold)
Old 04-23-2017, 09:56 PM
Thanks everyone I think I will stick with the E dizzy I currently own. Henry@supertec says it will be perfect.
Ben
89 944,85.5 944
914-6werkshop.com
Old 05-04-2017, 05:06 AM
Try not, Do or Do not
Henry Schmidt's Avatar
One quick thought.
If the case is 72 or later the distributor mounting hole is 30mm vs the 27mm of the 2.2 distributor.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-04-2017, 09:00 AM
Originally Posted by Henry Schmidt View Post
One quick thought.
Oops you are right the distributor is on its way to you with some repaired 226 fan rings
Ben
89 944,85.5 944
914-6werkshop.com
Old 05-04-2017, 12:21 PM
Hi Kenikh
I assume your concern (high compression) is based on the assumption that the 2.2S pistons on a 70.4 crank will produce a compression ratio in excess of 10:1.
That assumption has been floating around the Porsche community for decades.
The truth is, 2.2 S pistons don't produce anything like their advertised compression ratio (9.8:1).
In fact, when properly measured the static compression on all early factory pistons is considerably lower than the published number.
2.2S 9.8:1 crazy!
Actually measure at closer to 8.5:1
Henry Schmidt
Ph: 760-728-3062
Old 05-04-2017, 02:53 PM
