IMR-Merlin's Avatar
Well boys, the problem was found. The "mechanic" never tightened down the cam sprocket on the right bank, so the nut backed off, the pin popped out and all the valves on that side crashed.
We are leaning toward not splitting the cases. The car has a total of 90k on it and this is a second engine (Porsche warranteed the original).
All the bores look clean with a a good cross hatch pattern and no visible pitting. i will be borrowing bore gauges this week to check for ovaling.
I will be in need of 6 rockers, 3 intake and 3 exhaust valves. What do you think the chances are that the valve guides will be ok after crashing the valves?
Oh and good to meet some of you yesterday.
Brendon
82 twin plugged, EFI, G50 930, RSR suspension (soon to be) GT35R...
Old 06-11-2017, 11:34 AM
IMR-Merlin's Avatar
Also, just an afterthought. Since this is a *engine, what are the chances it's not a magnesium case?
The casting numbers are 901.101.102.7R
Old 06-11-2017, 01:59 PM
IMR-Merlin's Avatar
blah, disregard my last post... it's a mag case... ugh
Old 06-11-2017, 02:03 PM
Irrationally exuberant
ChrisBennet's Avatar
Brendon
There is a spec for measuring allowable wear. You lift the valve off the seat a certain amount and see how far it can wiggle. I don't know if that would apply to this situation. Being the conservative guy I am, I would send the heads to Anchor Atlantic and let him go through them. He will also catch the tired exhaust valve springs that the previous engine builder reused, etc.
He's very reasonable, especially as Porsche things go.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-12-2017, 05:46 AM
IMR-Merlin's Avatar
Thanks Chris, I will look up his information.
Old 06-12-2017, 07:59 AM
IMR-Merlin's Avatar
also, found out the issue on how the car jumped time!!
Old 06-12-2017, 08:00 AM
IMR-Merlin's Avatar
And the build thread on my car
new member 930 project
pictures got dropped, so most are here
https://www.facebook.com/BrendonMcQuaid/media_set?set=a.10203697233409192.1168236990&type=3
Old 06-12-2017, 08:07 AM
OUCH! I guess it wasn't torqued correctly!
Old 06-21-2017, 05:49 AM
IMR-Merlin's Avatar
Nope, not at all!! I borrowed the tool to remover the cam sprocket nut on the Left bank today from Dick and Precision.... it was maybe 20 lb/ft, and that is being very generous.....
Old 06-21-2017, 07:20 PM
wow
Old 06-23-2017, 06:32 PM
There is a spacer missing between the idler and the tensioner to fill the gap.
Bruce
Old 06-24-2017, 02:01 AM
