Originally Posted by mikedsilva View Post
As for your head to cylinder mating, I didn't use any sealant in that area.. what I did do, was lap each head to the corresponding cylinder using valve grinding compound to get a perfectly flat surface...
Engine has done a couple thousand kms so far, and no leaks whatsoever.
Thanks for replying to that question. It will come in handy as I progress to that point. Right now I'm just starting the reseal.
Old 06-26-2017, 03:45 PM
And the reseal starts. First up I inserted the new stud with a coating of Loctite 263. I did the same to one of the studs holding the oil pump in. As soon as the Loctite cures I can take the nuts off them.
Old 06-26-2017, 03:50 PM
Next up was a lot of cleaning with IPA, then blowing clean air into the galleries.
I then renumbered the bearing areas based on photos I took at the time of disassembly. These match the bearing shell numbers so everything goes back exactly where it came from. I cleaned each bearing shell with White Spirits.
Old 06-26-2017, 03:58 PM
Oil pump, intermediate shaft and chains installed.
Old 06-26-2017, 04:12 PM
Pic
Old 06-28-2017, 03:18 AM
Nose bearing seal inserted. Alcohol wipe, then bead of Curi T and pushed the Elring seal home by hand.
Old 06-28-2017, 03:21 AM
Crankshaft seal part-installed, assembly grease on bearings and place the crankshaft in. I didn't put it fully in as I need to do the nose bearing sealant at the same time as I start to seal the case. That will be this weekend.
Old 06-28-2017, 03:24 AM
Running in oil sourced. Mineral low detergent and high zinc.
Old 06-28-2017, 03:27 AM
