And the reseal starts. First up I inserted the new stud with a coating of Loctite 263. I did the same to one of the studs holding the oil pump in. As soon as the Loctite cures I can take the nuts off them.
Next up was a lot of cleaning with IPA, then blowing clean air into the galleries.
![]() I then renumbered the bearing areas based on photos I took at the time of disassembly. These match the bearing shell numbers so everything goes back exactly where it came from. I cleaned each bearing shell with White Spirits. ![]() ![]()
Oil pump, intermediate shaft and chains installed.
Pic
Nose bearing seal inserted. Alcohol wipe, then bead of Curi T and pushed the Elring seal home by hand.
Crankshaft seal part-installed, assembly grease on bearings and place the crankshaft in. I didn't put it fully in as I need to do the nose bearing sealant at the same time as I start to seal the case. That will be this weekend.
Running in oil sourced. Mineral low detergent and high zinc.
