tjonesMN
scored cylinders 4-6
2001 911 996 3.4l
cylinder 4 scored. cylinder 5,6 not much better. all pistons scored to some degree.
I know this has been discussed ad nauseam, but thought there might be recent revelations on this in regards to:
ways to fix/improve the existing cylinder to make it useable?
or
machine shops you can recommend for this repair (I am in the U.S.)?
or
any thoughts you may have
thank you.
Old 05-03-2017, 07:10 AM
Chain fence eating turbo
I believe Jake Raby can fix?
Old 05-03-2017, 07:51 AM
I guess my question to you would be why do you want to keep that 3.4? With 996 values the way they are, I would either a) find another core motor, or b) use it as a chance to upgrade by either sleeving it or finding a 3.6.
Old 05-03-2017, 01:49 PM
Puny Bird
Mark Henry's Avatar
LN Engineering, stock size 3.4 or upgrade to 3.6 or 3.8, new machined in nikasil cylinders and JE pistons.
I'm having an a 996 3.4 case done right now to 3.8.
Not only are they scored they're also out of round.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 05-03-2017, 06:49 PM
tjonesMN
[QUOTE=Mark Henry;9574738]LN Engineering, stock size 3.4 or upgrade to 3.6 or 3.8, new machined in nikasil cylinders and JE pistons.
This is the option i am thinking as well. Appreciate the input.
Old 05-03-2017, 08:24 PM
Puny Bird
Mark Henry's Avatar
Also was there a ticking sound you thought was your lifters that lead you to this?
There's likely nothing wrong with your lifters, it was piston slap.
Old 05-03-2017, 08:32 PM
Jeff Alton's Avatar
Not uncommon problem. Likely started in cylinder #6.
It requires sleeving and new pistons. You can choose to go the LN route with aluminum or use a Ductile Iron sleeve produces by LA Sleeves and sold through many machine shops, independent shops or the likes of EBS. A displacement increase will cost no more than stock at this stage.
We see a few of these every year now. Just completed a 3.4-3.8 conversion and are working on a 4.0
conversion that both suffered a similar fate.
Cheers
www.turn3autosport.com
Old 05-03-2017, 10:04 PM
prschmn's Avatar
They all go out of round. Send the case to Millenium and they'll bore and replate.
Get pistons from Wossner, replace all the usual wear items and you're good.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 05-04-2017, 04:05 AM
tjonesMN
Mark, not sure about the ticking sound. I bought this engine used for a very low price and started the disassembly process. Visually the lifters look very good and the valve guides are solid. nothing outside the 1/64 spec. I thought I made a pretty good gamble until I saw the pistons and cylinders. I think you are very likely correct in hypothesizing piston slap.
this post has provided some solid options to pursue. thanks for your response
Old 05-05-2017, 06:30 AM
tjonesMN
I will call them next. thank you.
Ken911's Avatar
OK so if they go out of round they were overheated. You can get them cryo treated before they get replated. I sent mine to L&N along with the pistons. they recommended getting them cryotreated before replating. They came back individually matched to each cylinder. Millennium actualy does the plating but if you send them to L&N they will pre check every thing and make sure you had the correct finish etc. for the exact same price as sending them directly to millennium
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 05-05-2017, 06:56 PM
Puny Bird
Mark Henry's Avatar
Millennium won't undercut LN in price guaranteed.
Old 05-06-2017, 08:19 AM
