here we go.
![]() cams timed and tensioners installed.
Instagram = glen.cordle for my Porsche artwork and 3D models. |
Yesterday we got the car running and driving!
![]() ![]() There are a few wrinkles I need to iron out. The biggest of which are sorting the power wire to the fuel pump. Something happened to it, probably where I had to man-handle the harness to weld the bulkhead engine mount on. I'm also not getting as much air through cyl#4. Based on the carb rebuild details, the most likely candidate is that I didn't get the valve adjustment right on that one. Carbs were gone through, throttle shaft bushings replaced, and the butterflies were set perfectly. I talked with my friend Dave Cheney that did the carb work and we are 100% confident in the setup on that front. A few other items I need to address before I put any real miles on it, but it feels strong and a great pairing for this chassis.
