wndsnd's Avatar
What is hot PMO set up for DP 2.7 9.5:1 DC 30 CAMS
Also intakes at 37.5 exhausts at 35.5
I know I will get recommendations from PHO or Clewett but I was wondering if anyone can give me their specs for a similar engine and your comments on results. Ie. Are PMO 46 too large?
Or what jetting and. Nets are you running on 40'S.
Thanks John.
1973 914-6 Conversion
2.7, crank fired, twin plug.
2006 997.1 Carrera S Cabriolet
Old 07-15-2017, 09:24 PM
SoyRacer's Avatar
40s 100%. Either Richard will set you up with proper jetting.
40mm for velocity/response and atomization from tip in to 9-k
46mm are best suited for 3.4 and larger (in my opinion) track use cars.
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 07-16-2017, 01:50 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
ditto
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 07-16-2017, 09:03 PM
wndsnd's Avatar
Got it. Thanks.
Old 07-25-2017, 01:18 PM
al lkosmal's Avatar
+1
RGruppe #669
http://www.x-faktory.com/
Old 07-25-2017, 07:42 PM
Or go with a Triumph setup which sits just between the two at about 43mm
No physical quantity completely explains its own existence
Old 07-26-2017, 05:27 AM
al lkosmal's Avatar
This is true. I've had great results with the Speed Triple units.
regards,
al
RGruppe #669
Old 07-26-2017, 07:36 AM
