996 engine from recycler with high leak down
I am helping a friend with his 996 which blew the IMS and its engine. He bought a used engine from a breaking yard in SoCal. We did a leak down test on it and one cylinder is at 80% leakdown. I am trying to contact the seller to find the history of the engine.
What is the likelihood of the engine sitting around for a long time having a bad leak down getting better after it has been run in a bit?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-04-2017, 08:01 AM
Anything is possible... though that's pretty bad. I wouldn't count on it "getting better" especially if you paid a high price for the motor...
Where is the air going? Take off the valve cover, look at the valves... Get a cheap scope and look into the cylinders.
Old 08-04-2017, 08:58 AM
Air is going out the exhaust ...
Old 08-04-2017, 09:40 AM
No way to save this one. Rigged up the engine to do compression test and got zero compression on 6. The engine is going back.
Old 08-05-2017, 05:50 AM
Puny Bird
Mark Henry's Avatar
That's the problem with a used 996 engine. Before install I'd scope the bores with #5 and 6 getting special attention, remove the sump/filter and inspect, oil analysis, crank push/pull test, 2000- replace the IMS, etc., etc.
Even then it's still a crap shoot.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 08-07-2017, 09:37 AM
It's a shame they didn't check it. There is so much more to these watercooled motors than just the IMS.
Bruce
Old 08-07-2017, 01:50 PM
