safe's Avatar
Push them out in the right direction, if you haven't thought about it. You don't want to push them out through the "thick" side.
Usually they don't push out either, they need to be tapped out, socket wrench extensions usually works nice,
Magnus
Old 08-22-2017, 12:24 AM
Originally Posted by NICE 69 S View Post
How long has this motor been sitting?
If you have to pound the rocker shafts out, you will probably score the cam housing. This may lead to leaks after assembly, no?
Bob B
Sure, if you pound it with a sledgehammer.
Cam towers are cheap enough and prevalent enough that you just buy new ones if it goes that way. And you're using RSR rocker shaft seals, right?
Old 08-22-2017, 08:47 AM
Stand back people, master mechanic here
I figured out the socket extension tip myself!! So proud! Thanks guys for putting up with me, look forward to more meetings like this Pro tip by Catorce was best, 'hit it harder!'
Old 08-22-2017, 04:35 PM
^Nice, that's exactly what I use, a big long extension like that!
Old 08-22-2017, 04:50 PM
gearhead
When it doubt, soak it longer or hit it harder. Sometimes both.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-23-2017, 09:27 AM
What's the point of beating it apart right now.
Drop the chain off the sprocket.
Pull the 12 head nuts and washers, chain box from the case and remove the whole unit
On the table there is so much more flexibility.
Bruce
Old 08-23-2017, 10:14 AM
