Chain fence eating turbo
Can I borrow someone's bolt stretch gauge? PayPal available on my end
Hello all, about to put my low end together for now and need to put my rods back on.
Can someone lend me their bolt stretch gauge? I no longer have access to one.
I can PayPal to your account.
Please let me know here or in a PM.
Thank you!
Cory
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 09-05-2017, 09:00 AM
I watched Turbocraft build a 911 motor on youtube.
They used ARP and they just torqued to spec. I didn't see them use a stretch gauge.
Seems to me if that's good enough for a 500-600hp 911 motor, should be good enough for me...
Old 09-05-2017, 09:50 AM
I hear you. Stretch is ideal as torquing can have varying results. The 3.2 rodbolts are small, so I put a lot more emphasis on them.
Old 09-05-2017, 11:01 AM
Not necessary for this application. Torque to spec with new bolts.
Old 09-07-2017, 08:08 AM
I have ARP, so reusing.
I have someone who will lend it to me. I'm good.
Old 09-07-2017, 08:13 AM
I have a Jegs gauge local in central Austin
free to borrow if needed
Old 09-07-2017, 08:45 AM
smokintr6's Avatar
Send a message via AIM to smokintr6
by the time you've shipped one both ways, you could almost buy the jegs one... seems like a waste to me.
Old 09-07-2017, 09:48 AM
The torque value provided by ARP is a recommended value. Stretching the bolts ensures the correct clamping force, and even clamping force, on each and every rod bolt. When stretching my rod bolts, I found the torque value to be all over the place. Some were right on spec from ARP, others were well above.
Sorry to get off topic, but use a stretch gauge on your ARP's. Their documentation even states that stretching the bolts is the correct method and you should ONLY torque them if you ABSOLUTELY do not have access to a stretch gauge.
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 09-07-2017, 10:52 AM
I hear you...
Just pointing out that on youtube, professional builders weren't necessarily doing that...
Old 09-07-2017, 11:23 AM
I hear you...
You just exposed the difference between a builder and an assembler. Big difference and should not be confused.
Old 09-07-2017, 11:44 AM
Stretch versus Torque for ARP bolts.......
Thank you!
Cory
Cory,
I did some tests and measurements to compare the stretch method to using just a torque wrench. The recommended torque will stretch the ARP bolts very close to the "recommended stretch value". However, the stretch method is a more precise method than the torque wrench method.
If the torque wrench is well calibrated it will do the job well unless you don't have a stretch gauge. If you have a gauge use both methods and compare your results. I applied about 90% of the recommended torque and measure the stretch. And finally apply 100% torque to get to the required "stretch value". If your torque wrench is accurate (correctly calibrated), you will get two similar results. Keep us posted.
Tony
Old 09-07-2017, 11:58 AM
Thank you! I believe I will be getting someone else's nearby?
Old 09-07-2017, 12:58 PM
^^^^^^THIS!!!!!!
I was pretty surprised how different the values were. I even used the ARP lube.
Old 09-07-2017, 01:01 PM
Originally Posted by boyt911sc View Post
Cory,
Tony
Being a former aviation mechanic, I just don't trust torque wrenches on critical fasteners.
I will always use the stretch gauge. Great piece of mind for me!
Old 09-07-2017, 01:03 PM
jdbunda's Avatar
Cory -
I was able to borrow a ARP stretch gauge locally - PM me for details. The JEGS gauge won't open far enough for the 911 ARP bolts.
John
John
1972 911T 3.0L Coupe
1986 Carrera Targa
1989 BMW M3
2007 328iT
Old 09-07-2017, 01:48 PM
Originally Posted by jdbunda View Post
Cory -
John
jpnovak located one for me. If it doesn't happen, I'll get with you.
Thank you!!!
Old 09-07-2017, 03:59 PM
scroll down
jegs gauge on a 964 turbo rod with ARP bolts
Forced to Deal with This
Old 09-07-2017, 06:29 PM
Gentlemen,
Because of my case business, I am a limited dealer for ARP, meaning I have access to the Porsche products only. I am not a reseller, but I do get the product at wholesale as well as the tech info.
The exact verbiage for ARP rod bolts is this:
ARP recommends using the STRETCH METHOD when
tightening the bolts. Following the instructions for using a
stretch gauge, Stretch the bolts to . 0095 - . 0100 .
If you do not have a stretch gauge, torque the bolts to
50 ft-lbs using ARP Ultra-Torque Fastener
Assembly Lubricant.
Many of the ARP bolts (that aren't rod bolts) just have a torque spec, and no stretch spec at all.
Additionally, the Porsche WSM for over 40 years lists only torque values...It is just within the last 20 years or so that they have thrown in angle measurements, in which case they will specify an initial torque value followed by an angle measurement.
Lastly, I have done business with Chris from Turbokraft and I can tell you that he has forgotten more about building air cooled motors than most people here will ever know. There is nothing wrong with the torque spec - millions of motors have been built by Porsche and enthusiasts using torque specs alone.
Let me leave you with this tidbit for those of you who are still overthinking this. When When I was in Stuttgart at the factory, I did the tour. A machine assembles the rods onto the crank, and this dude comes along and grabs a wrench that is affixed to the ceiling. He puts the wrench on each rod bolt, turns, and then it glows yellow WHEN THE TORQUE IS ACHIEVED.
Imagine that! A torque wrench at the factory, no less. And it doesn't even have any numbers, it just blinks when the torque is achieved.
Good enough for Porsche, good enough for me.
Old 09-07-2017, 07:31 PM
Atlas Copco torque drivers are far more accurate than your off-the-shelf click-type torque wrenches IMO.
Or whatever they use in Germany?
Old 09-07-2017, 07:42 PM
You would be very disappointed in the factory assembly......most of it is robots. Speaking of engine assemblers, that is where they work out of. No builders there. Not one of those guys on the line knows how to assemble a complete engine.
One guy does rod bolts all day long with a wrench that lights up, as I stated. Another guy does nothing but put oil pans on, then the block moves to the next station and a robot puts in all the pan bolts.
Old 09-07-2017, 07:50 PM
