GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Question Rough 7R - opinions
I have a rough looking 7R Mag case that id like opinions as to using it for my rebuild. All journals measured in 3 locations, averaged and within spec. My concern is the rough finish and some deep pitting inside the bottom of the case by the oil sump plate. I thought I may be able to fill these with JB or Weicon titanium repair stick.
Opinions
Old 09-13-2017, 04:49 PM
Since I build Mezger cases you will probably think I have a vested interest in this discussion, but I want to tell you honestly that in my development period for these cases, me and my engineers and toolmakers have looked at dozens upon dozens of cases.
I have NEVER seen a case that is that bad.
I personally would not build a motor out of that case.
Mag 7R cases are somewhat easy to find; I would find a better example.
Old 09-13-2017, 04:59 PM
Under the radar
Trackrash's Avatar
The big question is. Would someone abandon a good 7R case? Must be a reason for it to have been discarded. Any history on this case?
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-13-2017, 05:53 PM
I've seen a few myself and this one would be placed in the metal recycling barrel.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-13-2017, 06:20 PM
al lkosmal's Avatar
That is a crusty mother......I have never seen a case that bad............I'd replace that and move on.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 09-13-2017, 06:59 PM
Walt Fricke's Avatar
Hurricane damage from way back? Car drove into the ocean? Case set out in a sea side back yard. Or is salt water not that much a corrosive agent for this mag alloy?
Old 09-13-2017, 07:32 PM
Sandblast it, then make a coffee table out of it....
There are supposedly aircraft welders that weld magnesium. There was a thread on here a while ago about someone in Wisconsin welding the fan units...
Old 09-13-2017, 07:37 PM
GotaT's Avatar
Thanks for all the feedback. History - water and remaining oil sat in the bottom end for what appears to be a very long time. I sourced it for the crank which measured absolutely perfect; hatch marks could still easily be seen on the cylinder walls that hadnt corroded. My guess is the car was wrecked early in life and abandoned.
Old 09-13-2017, 07:51 PM
