Ingenieur
Carerra Pressure Fed Tensioner - Pop Sound
I was compressing a tensioner in the bench vice so that I could get the pin in and re-install it. I was squeezing it slowly with no results, and then I heard a POP sound. After that, it was easier to squeeze. I primed it and re-installed, and it seems to be pumped up. I cannot depress it with a screw driver, for instance. Do you think it is OK?
Compressing a hydraulic tensioners.........
Use a large C-clamp or a vise to compress it. Use an oil hand pump to fill it with oil. Keep us posted.
Tony Edit: Misunderstood your post. Thought you had difficulty compressing it. Last edited by boyt911sc; 11-18-2017 at 07:25 PM.. |
Under the radar
Only time will tell. If your chains are fairly new they probably won't skip a tooth if your tensioner fails. AHIK.
Check the ball and cage (nipple) to make sure it is still intact. Compare the tension to a known good tensioner.
It may be that there was something blocking something and you forced it out, if it holds tension, then there is likely no issue. |
1987 Porsche 911 Carrera Coupe |
trapped air escaping does make popping sounds....
80SC (ex California) |
Ingenieur
Thanks buddy, Yes, that turned out to be it. I did not know about the little leakdown hole until I found the tensioner thread that I recently posted too.
