1986 carrera Piston
undecided
..I have 40,000 miles on my 3,2L and it need to replace possible bent connecting rod
I thought maybe ,I may as well to upgrade the piston and cam at the same time ..
,it is worth getting the Euro 95.5mm piston or just keep the stock us version.... for sure later next year I may want go PMO ITB
I do now have the header and tune muffler
Old 11-23-2017, 04:09 PM
83 911 Production Cab #10
JJ 911SC's Avatar
I'm going with the Euro version and Web Cam as soon as I start her open heart surgery.
Who Will Live... Will See
Old 11-23-2017, 04:52 PM
I would do the 3.4 98mm cylinders because the JE pistons are cut for the more aggressive cams for your future injection.
Bruce
Old 11-23-2017, 05:51 PM
I heard that the JE piston only good for 50000 miles before due for rebuilt plus there are very limit cams spec you can use on those JE piston
Old 11-23-2017, 07:59 PM
Under the radar
Trackrash's Avatar
Originally Posted by frankoporsche View Post
I heard that the JE piston only good for 50000 miles before due for rebuilt plus there very limit cams you can use
Old wives tale. Maybe 50K miles of track time? Maybe JE pistons made 30 years ago?
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-24-2017, 12:18 PM
I don’t know how there would be a limit on the cams available, talking about limited, Carrera pistons will be limited.
Bruce
Old 11-24-2017, 03:44 PM
agreed
Old 11-24-2017, 06:37 PM
Bruce
I mean to say the only drawback the JE piston design are limits camshaft selection in higher performance applications.
Old 11-26-2017, 09:41 AM
Under the radar
Trackrash's Avatar
Not sure where you are getting this info.
You could talk to John Daugherty or Web cams if you are concerned.
I'm running JE 9.5 to1 95mm pistons in my SC with some pretty big cams. Not a problem.
Gordon
Old 11-26-2017, 01:10 PM
prschmn's Avatar
I'm curious about the "possible bent connecting rod"
Damn hard to do.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 12-02-2017, 12:42 PM
Damn hard to do.
well I didnt know for sure if the rod got bent...so far everything is looking good per spec.. my motor got flooded with excessive oil (Hydrostatic lock )
Old 12-02-2017, 03:12 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
That would do it :-(
Old 12-19-2017, 12:38 PM
