David 23's Avatar
Can't search for 3.2?
I'm trying to find out about the upgrades for a 3.0 SC engine, specifically the 3.2 short stroke upgrade I have "heard" about. However any search I do on this or the 911 technical forum with 3.2 in the title ends with no results. What am I doing wrong? Surely there are numerous posts regarding this engine upgrade or configuration.
1979 911SC 3.2 SS Custom Backdate Hot Rod
1972 911T, 2.7RS Spec
Beck 904 Carrera GTS /3.6
2023. Macan
Previously owned several 911 models since 1975.
Old 01-25-2018, 06:50 AM
KTL KTL is offline
Schleprock
KTL's Avatar
"3.2SS" would probably produce a lot of results. Or just "short stroke"
You are correct that there are a ton of posts on doing 3.0 --> 3.2 or 3.2 --> 3.4 engines via the 95mm to 98mm bore increase. The 3.0 --> 3.2 is called short stroke simply because you've got a 3.2 engine that arrived at such a displacement by its bore increase and maintaining its shorter 70.4mm crankshaft stroke. Compare that to the later 3.2 Carrera engine that gets its displacement via the same 95mm bore diameter as the 3.0 SC and uses the longer 74.4mm stroke crankshaft from the 3.3L turbo
The other reason I mention the 3.2 --> 3.4 is because the same approach for that engine "upgrade." Which is the typical bore increase to 98mm, as well as often changing the cam profile as well. 964 profile seems to be the most popular choice.
Kevin L
'86 Carrera "Larry"
Old 01-25-2018, 07:08 AM
I've tried too. It won't search numbers. key words like "performance" short stroke" Ect work.
Derrick
Old 01-25-2018, 07:14 AM
jmz jmz is online now
jmz's Avatar
...you should try a google search that included Pelican and 3.2 i've had same issue with this forum.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 01-25-2018, 08:36 AM
Chain fence eating turbo
Yes, use Google, and put in Pelican Parts after your keywords.
Much better search engine
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-25-2018, 09:09 AM
Registered Minimalist
75 911s's Avatar
Their crappy search wont parse decimals...which makes searching really hard. I use this custom google search set up by another member. You can search decimals there.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 01-25-2018, 09:31 AM
Right click on the forum address you want to search at the top of page and copy. go to google advance and paste address in the address bar there and then put 3.2 or whatever your searching for in the lower search bar. Mr Kontack helped me with this and the search results are spot on. its like a whole new pelican.
Old 01-25-2018, 10:55 AM
Y'all are overthinking this.
Just use Google.
Old 01-25-2018, 11:05 AM
David 23's Avatar
Thank you everyone. I’ll use google or post specific questions.
2023. Macan
Old 01-25-2018, 01:03 PM
Administrator
Dmitry at Pelican Parts's Avatar
Thanks for bringing this to our attention, in regards to the numbers not registering in the search - I'll bring this up to our tech team and see if we can solve this issue for you guys.
Old 01-25-2018, 01:12 PM
gearhead
Just use Google.
This.
I expected this would be resolved when they modernized the bbs software. No such luck.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-25-2018, 05:56 PM
Under the radar
Trackrash's Avatar
It's worth a try. BTW, this issue comes up from time to time. Problem is with vBulletin Solutions....
Google is the best option.
It's even worse, IMO, in the parts catalog.
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-25-2018, 06:11 PM
WP0ZZZ's Avatar
On the subject of cams for modified engines, Wayne's book on engine rebuild has a table of typical modified engines.
For the 3.0 -> 3.2 conversion with 46 carbs it recommends "S" or GE80 cams. Does anyone know who manufactures the GE80 cams?
For the 3.2 -> 3.4 conversion with 46 carbs it recommends "S" cams.
Old 01-26-2018, 07:25 AM
KTL KTL is offline
Schleprock
KTL's Avatar
GE 80 cams are Garretson Enterprises. Jerry Woods Enterprises is a good source for these. There's other cam makers like Elgin and Dougherty Racing that have profiles just like the GE cams.
The key here to what you mention for cams is that the carbs allow those cam profiles to be used with those engines. The tighter lobe separation angle, high lift cams like the S or GE80 cams typically do not agree with the CIS or Motronic injection. Additionally, those engines have an offset, semi-wedge piston dome with moderate compression ratio/dome volume to complement the CIS or Motronic injection and single spark plug heads. Whereas the S or GE80 cams are more conducive to carbs or MFI and the pistons are symmetric dome pistons with higher compression ratio.
Kevin L
'86 Carrera "Larry"
Old 01-26-2018, 07:56 AM
WP0ZZZ's Avatar
Cool. Thanks for the info, KTL!
Old 01-26-2018, 12:09 PM
