Tachometer
I had a 3.2 engine installed in my '76 911 - for some reason(s), the tachometer no longer works and the mechanic cannot figure it out ...
anyone has any idea(s) Many thanks |
tachometer issue
Thanks - i will check this out !
Under the radar
How is your tach hooked up now? You went from a three pin CDI to a 6 pin CDI.
When I did this on my car I hooked the tach to the coil, worked in my case. The six pin CDI has a connection for the tach, but not sure if your original tach will read that signal. The Carrera tach reads off the DME, I believe.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 02-03-2018 at 06:16 PM.. |
The tach drive on Carrera originates in the brain.
There is an adaptor in the front brain harness with the purple stripe black wire. That’s the tach drive, jump it to the back of the tach. Bruce |
The tach signal from the DME to the tach is a nice square wave, 5V I think. It should work with your earlier tachometer, but if not, use a tach adapter on that signal. It has all the very little current needed.
Don't mess around with running a wire (or finding an unused one) from the engine up to the tach. The DME knows very accurately what the engine speed is at any given moment - that's how it adjusts spark and fuel from the throttle position and other inputs. |
