Clackety clackety clackety clack
Hi everyone!
![]() My SC motor was rebuilt 4K miles ago by a very well respected shop (one of the best in Norway they say) before I owned the car, and the same shop did my PPI. In the PPI they mentioned hearing some engine clatter but didn't specify. I asked and they speculated it might be a chain tensioner, and that the car wasn't fully warmed up when they listened to it. I thought it was odd that a fresh rebuild would be making clackety noises (thats a scientific term btw) but well, it does. Nonetheless I decided not to stress about it, since it was newly rebuilt. The noise is really not that loud and the car goes like a top, but given that this is my first aircooled P-car I though posting a video might be a good idea. In the video the engine is fully warmed up, and the oil cap is removed until the end of the video-- the noises are easier to hear with the slow no-oil-cap idle. You'll need good speakers or headphones to hear it, and even then I'm not sure the sound comes through. The engine had 156K miles on it when it was rebuilt, below you will find the parts list, most of which is fortunately in English. Based on the list can someone tell me if this was a split-case rebuild or just the top end? Of course its not as though I can do much about it... my current plan is to drive it for a couple years and then rebuild again with EFI, but maybe you guys have some comments? TIA...
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
911 2.2 T targa
I have had a bad experience with clackety noises, but that was far louder than this. There are so many possible sources that it is really hard to judge based on a video. But I hear the sound and it is not normal. Best you can do is using an engine stethoscope to pin down where the noise is coming from and then try to find the root cause. What also helps is to determine the frequency. As the crank rpm is double that of the cams and if it is an exhaust leak it is probably once in 2 crank rotations. Good luck!
Straight shooter
When was the last valve adjustment?
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Without knowing for sure, I'd guess when it was rebuilt. Looking back at the invoice from the PO that was two years ago, and as previously mentioned the car has gone only 4K miles since then-- assuming the mileage was correct on the invoices. I'll have to look at some other documentation when I get home tonight too, I seem to recall that the PO telling me the car had done 6K miles since the rebuild, though he may not have remembered correctly. If he was right its gone 8K miles since being rebuilt including the mileage I've added to the car since March this year.
Somebody who has time to check all the part numbers on the invoice may be able to give confirmation of this, but because I didn't see main bearings or intermediate shaft bearings on the invoice, I believe that the work was just a top-end overhaul. I would start by pulling valve covers and checking valve clearances. If it still makes the noise after that, I would get the stethoscope out.
Straight shooter
I just watched the video. I think the noise is coming through the case not the heads based upon the tone and frequency. Does the noise go away when you step on the clutch?
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 08-19-2014 at 07:09 AM.. |
Another thing to check is whether the sound increases or decreases when you speed the engine up and drop it back to idle. Rod and piston pin knocks usually change noticeably when you do that. I didn't hear that in the video, but then again I'm not there.
Another thing-- I just checked the above with a cold engine, which is the first time I've put my head in the engine bay without the car being fully warm. The clack is more like a thunk, more random as well where as the clacking is consistent. None of this is a good thing well is it. I have to agree with RedCoupe that there don't seem to be any crank bearings on the invoice so in all likelihood this was just a top end refresh and the bottom end has 160K miles of hot weather use under it, at the hands of 14 owners before me. Car runs great though!
Double checked, rebuild was 4K miles ago as first thought. If something bad was lurking in the bottom end, how obvious would this be to an expert builder when he had the top end apart?
Could be chain tensioner noise, broken chain ramp floating around.
Could be a number of things. Narrow the location down by using a stethoscope or even a long screwdriver as a stethoscope, place the blade of the screwdriver at suspect locations and then place your ear against the plastic handle, you will be amazed at how this works. Likely locations are the upper and lower valve covers, the chain housings, etc. Does your engine have a sump plate? You can drain the oil and look for pieces of a broken chain guide. The next step is to remove the valve covers and check the valves and rockers. If you don't find anything there than a partial drop will give you access to remove the chain covers to check the chain ramps and tensioners.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 08-19-2014 at 01:04 PM.. |
Air Medal or two
Rocker shaft fell out
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
New chains and guide ramps with the rebuild (see invoice above) so I sure hope these haven't gone to pieces already! I'll have to get into the valve covers and rockers this fall then, and drop the sump plate when I change the oil before winter hibernation.
I wouldn't drive it till fixed, sounds like my old turbo diesel
When/if you remove those valve covers, check the torque on the head studs. After mine was rebuilt, they loosened up enough (after 2 thousand miles) so that I had a noticeable clack-clack coming from the head/case interface. Sometimes, a re-torque is needed. They are staying tight now and the clack is gone.
Good luck |
As mentioned, you should not drive the car, potentially you can cause a lot of damage to the motor.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
carrerarsr65
no case split
I see a master link on timing chain, no need for this part when case is split
Hi from a neighbor in Sweden!
Just one thought; wouldn't a bearing problem be followed by low oil pressure? In my experience, worn bearings mean the hot idle oil pressure is really low. So do you have any oil pressure problems? Regards, Johan
-14 Cayenne S Diesel, DD -92 964 C2 convertible, RS -92 look and feel😃 -73 T US MFI Targa, restored -70 T Coupé Hot Rod, painted waiting for assembly -72 T Coupé, US numbers matching under restoration |
Hi Neighbor! If we are to trust the pressure gauge on the dash, then oil pressure hot is just fine. About 1.5 bar at idle, climbing along with revs. Please explain. Quote:
Air Medal or two
The rockers shaft is held by pinch bolt arrangement .
Lots of times not installed correctly and or not enough torq on pinch bolts . The can back out and flop all over the place
A little update. I spent some time with a screwdriver on various engine parts and to my ear. The noise is damn loud in the ear when doing this, and sounds like "kak kak kak kak kak kak kak kak kak..." The frequency at idle (around 800 rpm this time) was just about four "kak" noises per second and perfectly even. Speeds up evenly with revs. Does this tell us anything?
The noise is equally loud no matter where I put the screwdriver-- intake plenum, timing chain covers on both sides, top of the AC compressor... yeah, everywhere. Haven't tried on valve covers though. And finally, another possibly important detail, when shutting off the engine there is a pronounced mechanical clatter, same clackety-clacketey sort of noise. This with the tranny in neutral and clutch engaged, I haven't tried it while in gear/clutch out. I'll get video of this scenario tomorrow.
