Valve guide question
Looks like my machine shop had a little trouble with one of my valve guides. What would you do?
It’s not going to bypass oil or cause excess wear, I d run it
Bruce |
Request that they redo it. I'd be surprised if that showed up at my door from my machinist.
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
That flange has a pretty good divot in it. You should address that before bolting the headers on.
Thanks. My thought was to check it myself. Its a chance that it was cosmetic on the outer surface. That said, I agree that it should not have left his place like that and will let him know.
Good eye on the divot in the flange. I will take a close look at that too. Appreciate the great comments. |
Actually on mine the guides were installed then it was cnc ported that part of the guide was milled off. So as long as the valve clearance is ok. It might look bad but is most likely ok.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
Looks like on old guide to me...not a new one.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
I can see by the picture some nicks at the end of the guide if someone blocked off, which I see they did the air injection port they may have dressed as it entered the port and nicked the guide with the burr.
regards |
