Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Typical Fish's Avatar
Gas Gauge Problem...
Interesting problem...
I filled my tank on my 2001 325i this morning, I was at about 1/4. After 23.00$ worth of fuel, and the lever clicking off, the guage still had not moved. I tried putting in more gas, thinking the pump might be in error, but the car is indeed full. Now the weird part; it is not stuck, as it continues to go down from the 1/4 tank (it is now at 1/8) and the trip computer shows the appropriate number of miles less left. I have tried turning off the car, etc.
Any thoughts? I am perplexed. Thank you in advance.
Matt
Old 03-20-2003, 08:06 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I know that my fuel gauge seems to have a mind of it's own as well. Sometimes it seems to stick at a certian point, sometimes it fluctuates. I'm suspecting that the contacts inside the the fuel sender might be worn out, or possibly a poor ground somewhere, however on a car as new as yours, i don't know what would cause it. The fuel sender may be bad. Is your car still under warranty?
Old 03-20-2003, 08:19 AM
1500 miles out of warranty. Figures. The thing that is weird is that it seems to functioning, just not calibrated.
Matt
Old 03-20-2003, 08:21 AM
Normally i would suggest that you check ground connections, however on a car that new, I doubt that the wires would have corroded or built up resistance.
Anyone have any ideas?
Old 03-20-2003, 08:25 AM
Senior Advisor
Javier at Pelican Parts's Avatar
the fuel sender in the tank
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 03-20-2003, 08:33 AM
Jav,
you think the sender is bad?
Old 03-20-2003, 08:34 AM
Senior Advisor
most def. these are common for these cars. We used to replace them all the time.
Old 03-20-2003, 08:35 AM
Well there you go,
Learn somethin new everyday. What is involved with changing the sender? Is it under the rear seat?
Old 03-20-2003, 08:37 AM
Senior Advisor
Yea realy kind of simple remove seat expose senders (perferably with empty tank, well vented, keep flame away, no sparks all that jargon, replace also new seals.)
Old 03-20-2003, 08:40 AM
You will also need some hog-ring pliers to remove the clamp that holds the sender in the tank. If you send me your email address, i can send you an article that kinda goes over how to do this, although it is for the E36, the idea is the same.
Old 03-20-2003, 08:42 AM
