Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Typical Fish's Avatar
Stalling problem...
My 2001 325i has a stalling problem once the engine is warm; it stalls at takeoff, it almost feels starved for fuel, then starts right back up. This is now happening sometimes 5 times a day, then other days not at all.
Thoughts? Experiences?
Matt
Old 02-10-2005, 06:51 PM
Matt, have you solved this problem yet? My '01 325 did this Friday for the first time. On take off from a light, it would just stutter and stall. Of course, the dealer couldn't reproduce and there was no code.
Jeremy
Old 05-31-2006, 08:48 AM
e46 stalls
i have a 325i CI 2001 & i have had this issue with mine it stalls when the revs go down, & when the pc is connected it states cam shaft sensor, but i have been told there are 3 sensors but u cant tell which one is faulty
Old 06-15-2006, 02:21 PM
Lightbulb
my 325 has now stop starting so i am in the process of changing all 3 sensors any ideas from any one & i hope this is the fault
Old 06-15-2006, 02:24 PM
ajr ajr is offline
stalling
I had exactly the same problem, the car would drive fine and then stall on deceleration or on acceleration away from lights or a junction. The codes were unreadable on the garage machine and had to be sent off to BMW's main diagnostic machine (who still couldn't read the codes!). Anyway the garage eventually replaced the camshaft sensor and the water pump sensor and all seems to be running fine !
I now have a broken rear hinge window switch - it never ends with this car! Any ideas?
Old 06-25-2006, 02:47 AM
I have the same exact problem but my code (P1397) reads that the exhaust camshaft sensor is faulty, does anybody knows where is it located?
Old 06-26-2006, 08:01 AM
Jeron's Avatar
http://www.realoem.com/bmw/showparts.do?model=AV53&mospid=47725&btnr=11_2170& hg=11&fg=15
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 06-27-2006, 08:16 AM
