Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Leaking Temperature Sensor Fix
When the temperature sensor in the lower radiator hose on the wife's '04 330i started leaking, I went crazy looking for an O-ring that would fit. I finally gave up and bought a new temperature sensor.
I just found a thread on another forum that indicates that o-rings of the correct size (or close enough, anyway) are available. o-ring #31
Ace Hardware sells a #31 o-ring for $0.59.
Home Depot sells #31 o-rings in pak of 10 for $1.79
I have not tried this personally, but I will definitely try it when my 325iT starts leaking, which it will eventually.
I actually looked at Ace Hardware when I was o-ring hunting. Guess I did not look hard enough.
Old 01-19-2013, 11:07 AM
