Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Axel (guest)
Guest
Posts: n/a
Hi, I have a 2001 BMW 318ti - it seems to backfire once the engine gets up to normal temperature, but is fine whilst the engine is cooli.e. just after starting it... Do you know what might be causing this? I think it might be a sensor?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW 3 Series (E36) Oxygen Sensor Replacement
Old 05-31-2013, 04:58 AM
Nick at Pelican Parts's Avatar
i would inspect the crankcase breather valve. A backfire could be caused by ignition timing or a lean condition.
- Nick
Get a can of spray starting fluid and spray it around the intake manifold to look for vacuum leaks while the car is warm and running. Also examine the whole air path looking for cracks. My money is betting on the intake manifold gasket.
Old 05-31-2013, 05:48 AM
