Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Question Check Coolant Level
Hello,
The Check Coolant Level warning light (2000 540i) comes on after a few minutes of driving. Coolant level is ok and even replaced the coolant level sensor. Engine is not overheating and don't have to add coolant at all. Any advise is appreciated.
Thanks,
2001 bmw 325ci
2000 bmw 540ia
2000 bmw 328i
1995 tyt 4 runner
Old 02-17-2004, 09:27 PM
x_atlas0's Avatar
I had a similar problem a while ago. My water pump finally gave up the ghost at 120k miles, with symptoms very similar to what you are describing. Just something to consider.
1994 540ia
2000 540is
"Could be worse."
"How?"
"Could be raining."
<proceeds to rain>
1994 540i modded to heck
1973 3.0 CS converted to 3.5L/Motronic/5 speed
Old 02-21-2004, 10:51 AM
Thanks for the info. I'll keep an eye on my water pump.
2001 bmw 325ci
2000 bmw 540ia
2000 bmw 328i
1995 tyt 4 runner
Old 02-22-2004, 07:32 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
It could also just be a faulty coolant level sender. I would check the sender on the reservoir tank and see if there is any corrosion on the terminals. If so, clean the terminals out with some contact cleaner.. I did this on my own car and it solved a random check light problem.
Old 02-23-2004, 10:09 AM
