Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Replacing Spark Plugs on a E39
I would like to know if changing spark plugs is an easy task. I have 134,000 Miles, last night I pulled the cover and noticed sparking around the packs. Are the coil packs bad also?
R
Old 03-12-2008, 07:33 AM
Jeron's Avatar
Replacing the plugs is easy but take your time.
If it is sparking form the coils then the engine should be running rough. Also, you should be able to see where the sparking is from when you pull the coils.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 03-12-2008, 08:19 AM
Jeron,
Do you have a step by step approach to replacing them? I was told by a BMW tech that i should replace the rubber boots also. Should i use BMW only parts to replace? You are right the engine run rough.
Rod
Old 03-12-2008, 08:41 AM
Jeron's Avatar
Engine cold
blow out the wells to get any debris out of them
I put a very thin coat of anti-seize on the threads
dont cross thread
use a torque wrench
I would be concerned about what caused the boots to degrade. Are all of them bad? Definitely inspect and replace anything that is cracked or dry rotted.
Old 03-12-2008, 09:12 AM
Gus540i
Ditto on the anti seize, cheapest insurance you can buy
Old 04-06-2008, 08:10 PM
