Guest
Posts: n/a
I replaced the brakes on may 528i. 2000. And the dach light won't go off how do i reset it.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Resetting BMW Airbag Warning Lamps (SRS Reset) |
Author of "101 Projects"
The brake pad sensors control this lamp. If the sensors triggered the lamp to begin with, then you must replace them (they are one-time use only). If they are brand new sensors, then the connector is probably not well seated in the plug. I would unplug and then replug in all of the sensors to make sure the connection is good.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
'79 911SC TARGA
Wayne is right on the money, I just did my brakes and had the same problem. Replaced the sensors and all is good now.
CROW '79 911SC TARGA '05 BMW 525i '98 HARLEY HERITAGE SPRINGER '11 Ford Edge |
