Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
ednaearle (guest)
Guest
Posts: n/a
I have a 94 530i and have replaced two o2 sensors but the car still cuts off at light if sitting for a short time and sometimes a smell of gas is in the car.... do I need to replace the other two sensors?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW 3 Series (E36) Oxygen Sensor Replacement
Old 04-17-2011, 07:44 PM
Author of "101 Projects"
Wayne 962's Avatar
Probably not - that probably is not the problem. A gas smell inside the car means that you probably have a fuel line leak or a seal on your gas tank is leaking. I would check out the article on fuel pump replacement in our tech articles section here and see if the problem is with the seal or the pump.
- Wayne
