Finding No Substitute
Intermittent stalling and erratic idle
1995 540iA. 236k well maintained miles. Only happens occasionally, and mostly when throttle is at idle, either at a stoplight or in park. Following codes popped up: lambda 1 lambda 2 and ac compressor.
Cleaned ICV and car ran better, not sluggish anymore....seemed to shift better...but still has stalling issues....o2sensors? Any advice? She goes into the shop Friday. Thx, John |
In the shop at Pelican
Without the actual codes I cant tell you for sure, but bad O2 sensors could cause this.
C9 and Cb if I remember correctly...and 41 (ac compressor). Odd since the a/c has been working flawlessly. I do get a kind of hum from the passenger side as well, not sure if it is realted.
Those arent OBD2 codes. How did you get those?
Peake codes. I have the diagnostic tool.
