Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
BMW Roundel too lean fault code
car = 99' 540iA
My idle is too low, around 450 rmp, car occasionally dies. OBD error codes indicate too lean right bank and too lean left bank.
My car runs as well as the day I brought it, no other problems, 80k miles, any suggestions on what could be causing this???
Thanks guys.
John
Old 02-03-2003, 08:47 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Could be the O2 sensors. Have you done any work to the enigne at all?
Old 02-03-2003, 09:50 AM
no, nothing but standard maintenance. Wouldn't the OBD II code indicate a fault in the O2 sensors? A friend of mine said it might be the mass air flow sensor too. How would I know without paying out the ying-yang at a dealer or needlessly replacing parts?
Old 02-03-2003, 10:00 AM
How did you detemrin it was running lean?
Old 02-03-2003, 10:01 AM
I plugged a OBD II scanner into my OBD II port to the left of my stearing column. It game me 2 fault codes: 1 = P0171 and 2 = P0174.
In the manual for the scanner, it states that these codes are "Lean left bank" and "Lean right bank" respectively.
Old 02-03-2003, 10:05 AM
Sounds like it could be an intake manifold leak. On some Ford's a cracked lower intake mainfold gasket caused the same codes.
Old 02-04-2003, 09:08 AM
I would agree, if it's not O2 sensors, it's most likely a leak. Check your vacuum lines.
Old 02-04-2003, 09:11 AM
I might be sounding like an idiot here, but, the only other car I work on is a 78' Trans-Am (35k miles on it, my first nice car, picked up when I was a kid), on it, I just hook a vacuum gauge up to my manifold line and read.... that simple. Question, is there a easy way to test for vacuum leaks on a 99' 540i, what should the vacuum be, does it differ depending on where I hook a gauge up, etc....
If you could point me to a web site or a prior post, I would greatly appreciate it.
thanks
Old 02-04-2003, 10:38 AM
How do I know if it is the O2 sensors without replacing them?????
thanks
Old 02-04-2003, 10:39 AM
If you send me your email address, ill send you an article on how to test the sensors
Old 02-04-2003, 10:43 AM
Bob540iA's Avatar
Here are a couple links that may help.
http://www.bmwe34.net/e34main/trouble/engine_diagnose.htm
For info on vacuum testing.
http://www.mr2.com/TEXT/O2_Sensor.html
For info on testing oxygen sensors
Bob M
1995 540iA
1988 535i 5 Speed
1980 528i 5 Speed
1980 528iA
Old 02-08-2003, 12:03 AM
BMW Roundel too lean fault code RESOLVED
Just to let everyone know, it was my Mass air flow meter. I hooked up my palm pilot to my OBD II port, ran "live" for about 50 miles, graphed out the Mass air flow vs rpm and MAF vs Fuel trim (right and left) and it indicated (at least that is what I thought) that it was not the O2 sensors, or, if it was, coincidently, they both failed at the same time. I was right, problem solved.
John
Old 02-20-2003, 04:39 AM
