Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
Ac compressor noise
My ac compressor is making a squealing noise at start up.
Are the bearings going bad ??
Pulley ??
Belt ??
Old 09-20-2018, 08:00 PM
That description leads to a number of possibilities.
From your list, could be loose, worn belt or belt tensioner going bad.
Could be a fluid leak that wets the belt or pulley that gets cleaned off after a bit.
Could be a clutch or compressor bearing starting to fail, or a clutch bearing that has failed and shuts up when clutch is engaged (the AC compressor clutch of course).
Could also be power steering pump or water pump.
Could be a bad compressor or an overcharged AC that allows liquid refrigerant to get to the compressor.
Need more trouble shooting done.
Sent from my Moto Z (2) using Tapatalk
Old 09-24-2018, 06:34 AM
shogun's Avatar
First of all tell us the 7 model, type, built year
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
http://twrite.org/shogunnew/topmenu.html
Old 10-26-2018, 01:18 AM
