Same lack of power problem new topic
Now that I know that my Cam sprockets are stock I still keep digging, someone on FB group mentioned stick coils, but they are new, why not check again.... No fire on left side, swap left right, still no fire ON THE LEFT! Also left plug looks like it never sparked: electrode is brand new, no erosion, no heat, so I assume dealer saw no spark, replaced coil and called it a day....
Now I got to find why left side is dead, assume bad wire, but I need to find a diagram for this bike, 2004 twin spark
Old 11-22-2018, 05:24 PM
Matt, How does the bike run if you disconnect both lower plugs?
This diagram will get you close: https://www.mac-pac.org/wp-content/uploads/2014/09/R1150RT-2-Plug-Elec-Diagram-V1_3.pdf but fuse numbers will be different.
I have full schematics if there’s something else you’d like to know.
Old 11-23-2018, 03:33 AM
Awesome, thanks!
this confirms my fear that each coils is triggered by ECU directly, they all have common power and separate grounds, so if I have connectivity from coil to ECU pin I will be needing new motronic unit
Old 11-23-2018, 07:44 AM
Brent
ive not seen a bad motronic I might have a spare
Old 11-23-2018, 07:53 PM
Mystery Solved! (I hope) not sure how I missed it, seems it's barely held together by some plastic... bet whoever did the plugs last time broke it...
Bought used Motronic because one came up cheap ($100) so now I will have a spare
Now a million dollar question: where do I get a coil plug?
Old 11-23-2018, 09:41 PM
Brent
should be a spare on the harness repair page of the bmw parts diagram
get the contacts as well
it looks fubar
Old 11-23-2018, 10:41 PM
it looks fubar
fubar for sure, electrical contacts snapped clean off, all 3... lot's of headache and 1000's of miles with slow bike. Wish I had known, kept telling myself "BMW is not race bike..." and even tried selling it because it was so slow, but always hoped there is an easy fix, wish I had known....
Old 11-23-2018, 10:57 PM
Can that plug be ordered without any wires ?
I just want to buy the plug.
2004 R1100S
Old 11-24-2018, 03:41 PM
2004 R1100S
mtgill's Avatar
I think what you're looking for is #9 on this page.
https://www.ascycles.com/bmw/1999/R1100S/Engine%20electrical%20system/Ignition%20system,%20double-ignition.html#PartsTable
I broke one of those connections many years ago. From what I remember, it's a simple fix. If my memory is correct, the plug comes pre-wired with a short length of wire to be soldered to the existing control wire. Cut the old on off, solder the new one on.
Mike
2004 BMW R1100S, 1982 Piaggio PX125E, 1972 Kawasaki H1B, 1969 Honda CB750, 1970 Yamaha XS1, 1970 Yamaha R5, 1965 Ducati Sebring.
Old 11-24-2018, 07:53 PM
Mike
Looks like I can get a universal plug from BMW for $25 or so, fits coils and other things
83 30 0 402 341 REPAIR PLUG, 3-PIN - NO. 610616
Old 11-24-2018, 10:28 PM
Brent
if you cant find one let me know
I might have one out of a donor harness
Old 11-25-2018, 05:36 AM
I see you
flatbutt's Avatar
Always worth checking here https://www.beemerboneyard.com/
Old 12-01-2018, 05:39 AM
got everything from MAX BMW, wire repair kit, spark plugs, air filter, valve cover gaskets and o-rings, working on assembly. Replaced brake lines while the tank was off, might get it finished in couple days, not much work left, just need to find time
Will test and report back once it's done, of course today is last reasonably warm day in the extended forecast, dropping from mid-50's in to 30's, luckily thins bike really shines in cold weather!
Old 12-03-2018, 05:45 AM
Finished assembly and went for a quick ride, HOLY ****!! IT HAS BALLS!!! Even lofted front wheel few times. No more chugging, shaking, stalling, I'm in love with it again!!
Old 12-03-2018, 12:56 PM
Was you able to find out any info on this plug ?
Is it the wrong plug for the coil .
The coil plug is fragile. It would be nice to replace the plug, and not having to buy
the " wire repair kit" .
2004 R1100S
Old 12-03-2018, 03:30 PM
It is a plug with some wire length coming out (3 wires) and 4 crimp connectors, also 4 very heavy heat shrink tubes, I'm guessing extra in case you screw up.
It was maybe $23? wrong color, but who cares, bike is running like raped ape!
Old 12-03-2018, 03:57 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
Mike
'07 R1200S
Old 12-03-2018, 06:02 PM
Rode it again this weekend to a brunch 40 miles away... was so excited to use the bike that I went out in a pouring rain and then spent the rest of the day on it, went to work then couple parties, came home late night in freezing temps, in love it it all over again, can't believe I was ready to sell it
Old 12-24-2018, 04:41 PM
