Setting Correct Timing W/O Cat-Code
Just wondering if pulling the cat code plug would throw off setting the timing properly. I have to bring my bike in for service, and was told by BMW tech that the timing was pretty far off, which caused the bike to backfire badly on decel . They couldn't adjust right away, and since then I pulled the cat-code plug. Gotta say it feels SO much better than before with regards to the on-off throttle response. ( thanks all) Anyway should I put it back in before the service, or is it ok to leave it out?
leave it out...they should never know the difference.
repoe3
I couldn't repair your brakes, so I made your horn louder. 2009 GSXR 750 2004 Tuono 2004 R1100SBX |
This has probably been asked before, but is there any benefit to leaving the cat code plug out if you already have an FIM chip installed in the Motronic unit?
well, i have answered it before, but.
the fim chip has the same map over all 8 possible maps, so it will make no difference. the ccp is used to change between maps with the std chip.
'89 851 '97 600m '65 Hunnybunny '05 Little man |
Ok that's what I thought, thanks Brad. Maybe I'll yank it anyway to save some weight. I'll do a comparison to see if the handling improves any.
HA!
BMW: 2024 R1250RS, 2016 R1200RS (For Sale), 2000 R1100S, 1975 R90S Ducati: 2008 S2R1000, 1998 900 SS/FE Norton: 1974 Commando 850 Triumph: 2020 Speed Triple, 1976 T140V Bonneville, 1973 TR7RV Tiger, 1971 T120R Bonneville, 1970 TR6C Trophy |
