SilverR1100S's Avatar
Thumbs up place the magnet
Hi there
I also mounted a little digital speedo.
And I also lost the magnet several times because of high speed.
Now I mounted the magnet in the middle of the wheel.
see the pic
It stays in it's place even when I drive 200 + for a while.
see you
Coos
Titan-silver R1100S
Old 08-12-2003, 11:26 AM
Endurologist
rob_wijhenke's Avatar
I never lost the magnet which is mounted on the rim with a small amount of bison tix. Great stuff and removable too,
The Latest is the Greatest
'09 HP2 Enduro - '06 m620 - '08 Koga XPM-M
CB200, XS750, GL1000, GL1100, R80RT, 2xK75S, F650, RF600, ZF600R, 750ss, 888corsa, 900ss, 3xR1100S, K1200R, R1200S, R1200GS
Old 08-12-2003, 02:14 PM
Here is my set up. I figured if you don't want to lose the magnet, then mount it as close to the center of the axle as possible. With a tiny piece of double stick tape, the magnet has so far remained in place for over 15k miles. The side benefit of mounting this close to the axle is that it has less of an affect on wheel balance.
To measure curcumference, I wetted a small spot on the concrete , then rode across and past said area couple of extra tire rotations with my full weight on the bike, then took measurements.
I've compared the bicycle speedometer to the local police speed indicators, and it is spot on. The bmw speedometer reads 7 mph higher. Funny thing is both the bmw odometer and the bicycle odometer pretty much match.
tony
Old 08-12-2003, 08:02 PM
