Hey Gang;
When I Had the Bike Dyno'd last friday, Took the bike out of the shop and the ABS wouldn't reset with just turning the bike off and on. ![]() So I had to take the bike to the dealer to have it reset!!! It was because the front wheel was locked and not turning, which made the ABS system think their was a problem and set a fault code. Anyway $30.00 dollars and it was reset!!! My question is this Is their a way to disable the system so when I put it back on the Dyno it won't do the same thing? Asked the BMW shop and they didn't have an answer to my Question. Also what is the Life of the Fuel filter? Mine went belly up at 20,000 sounded like something from Star Wars
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel ![]() 1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Fuel Filter gets renewed on Inspection III (24,000 miles) Per the 1999 manual
Okay, What about the ABS faulr code?
Start the bike immediately after turning on the ignition, ABS will be disabled and thus not detect the fault ?
