pwillikers's Avatar
I love you guys.
So... to answer my question, the voltage setting on the tps is independent of the motronic version. We have the same settings, .37~.4, as the older R's.
And, the higher the reading, the richer the mixture - for very small throttle openings where surging occurs. But, stay below .4, the approximate value at which a fault is registered. I think I'll set it at .395 (per Roger) and see if that cures the surging.
Paul. '11 R1200RT, '09 Buell 1125cr, '08 Suzi SV650A, '00 Suzi SV650, '97 328i (with sticky ass tires - I love this car). And the bikes I used to own: '68 Bultaco 100, '69 Honda CL450, '71 Kawasaki Mach III, '71 OSSA Pioneer, '72 Honda MR175, '72 Benelli 250, '75 Yamaha RD350 (then college), '83 Honda VF750F (then kids),'96 MZ Skorpion, '99 R1100S, '01 SV650, '94 Honda VFR750F and '04 R1100S w/Öhlins an' stuff, most wrecked.
Old 11-06-2003, 09:02 AM
MarkC's Avatar
Location: While a member here: Japan - Germany - USA - Curently: UK
From my personal and unprofessional experience here's a couple of tips I learned.
1. Attach the neg lead from the Digi-Volt meter to one of the two 'TPS retaining bolts' (or that little brown ground wire under the throttle body) for a good consistent ground (I've gotten different values when I attached the ground lead from the Digi-Volt meter to other parts of the bike).
2. Read the voltage and adjust with the bike's engine running. I found that with the engine not running, the voltage reading would start at .330 then move up to around .350 ~ .370 pending on how the battery is. So to get a consistent voltage reading, I have the bike’s engine running.
My S from the factory was set to about .330 volts, read with the engine running. Mine is now set at about .360, again with engine running.
MarkC
Old 11-06-2003, 11:27 AM
roger albert's Avatar
Hi Paul,
I'd second MarkC's good advice on measuring with the motor running.
Let me clarify what said (or meant to say) I've had good results up to .395 or a little more, but generally like something a bit lower (which also helps keep idle realistically low) .375, or even down towards Mark's .360 can work well. I'd be tempted to start around .375 and then play a bit. Good luck
Roger
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 11-06-2003, 12:27 PM
