to all...i am glad i could provide the phots and write-up, but really, i was no way in a position to do this kind of project on the bike without wswartzwelder's help. in fact i got in the way
he employed a nasty little trick to get me out of the way by flicking or spraying gas in my eyes...i caught onto him pretty quickly though...i am not that dumb ![]() repoe3
I couldn't repair your brakes, so I made your horn louder. 2009 GSXR 750 2004 Tuono 2004 R1100SBX |
unsafe at any speed
regarding the subframe, rear frame being removed as one piece.... there are alignment issues when reinstalling the rear frame, wiring harness on the left and fragile fuel injctors and lines on both sides... trying to wiggle things into place with the extra weight could be quite difficult... the four bolts needed to remove the tail section just takes a moment and makes things easier to handle. The clutch push rod was rusted and stuck in the input shaft requiring a smack with a mallet to remove.... I believe this was the cause of most of his trouble. Glad that everything is working fine for you. Enjoy.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Repoe3,
Just out of curiosity, your bike must be under warrantee......why did you not let the dealer handle this for you? Did you just want to learn how to fix this yourself? BTW, I wish I was as mechanically knowledgeable about the S. Robert
moved from Chicago to Charlotte so I could use the sides of my tires
repoe3
in fact i thought hard about a used kawi Z1000 to add to the stable just for ****s and giggles. but yes, ultimately it is about learning about how things work and being abel to tackle future challenges.my knowledge is still at a basic level of servicing and maintenance. this was the first major project i have ever tried and could not have done it with the help of others and their willingness to help. if, well more like when, i need to do this again...i think i could do it on my own, but having a helpful hand and the great riding...i may just have to go back to arkansas to do it again ![]() repoe3
A Truly Stupendous post! My impression is, the patient had to be killed first in order to survive. If I ever take my bike apart to that level, I'll just part it out...
'01 BMW R1100SLA. Turbo. < = > Less is More. If you think you know it all, you obviously don't know anything. |
unsafe at any speed
Repoe, you are quite capable mechanically.... give yourself some credit!!! The truth be known... repoe wanted an escape from his everyday work. Disassembling, working on, and riding is fun for some people. I think repoe was looking for an adventure over the holidays... Thanks for allowing me to participate Repoe.
Motoman, I feel that way about computers...I hate working on them, there comes a time to replace something if it is more trouble than enjoyment.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 01-03-2005 at 09:02 AM.. |
repoe3
Great post. I've been in to this area several times on R1100RSs, and FWIW the job looks even easier on an S. Being able to remove the rear subframe and wiring so easily is a big plus. I also encountered the stuck/rusted clutch pushrod problem on the gearboxes I pulled. I just want to know how you kept the front of the bike balanced so nicely on the workstand???
'07 R1200GS Adventure "Brutus" |
unsafe at any speed
The stand has holes that allow the bike to be bolted down to the stand.
Dudes, that ***** was HARDCORE!
Thanks for the insight. Having my hand held at a Tech Daze for the RT was about as much as I could handle. (Never had really worked on anything like that. Wound up doing a fuel filter replacement and alternator belt replacement. OY, it was pretty intense for someone who's never really wrenched on anything.) As it is, I do good to change my oil.
The pioneers had a hard life but, sometimes someone would break out a fiddle....And make it worse. |
Living on borrowed time!
good documentation, Repoe; mine is gonna look like that shortly (I went on a nice ride yesterday; got the oil warm for draining). Now it's time to rape brunhilda right down past her knickers and hoist that frikkin' getrag box onto my workbench.....then, it's input shaft removal. Depending on what Moybin finds out about making one outta good ol 'merikan chrome-moly is whether or not I will have my OEM shaft microplated or have the NEW one plated, but I WILL be coating mine with some sort of dry antifriction coating...
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
i wonder if PAM spray would work...spray it on and bake it a bit...they make a PAM for grills now that can handle heat and fire. maybe thats the ticket
what is the shaft made out of, anyways? would a different shaft material change its operation if its weight is different, etc? throwing out wild questions to better understand how sensitive, or not, these things might be. wonder if TiNi would work or if that is just for stiction reduction. i have a writing pen and had a knife that is coated in it or Ti oxide and nothing scratched it. the knife survived my last crash even after being pulled from my pocket, opening in the road and being run over by cars. kershaw sent me a new one coated in black teflon or something more like gun kote or the k-kote on sig sauers. seems to wear like my pistols do goin in and out of holsers.repoe3
Thanks, repoe. That's going to be a useful reference, maybe for me this winter as a prophyfreakinglactic measure.
02 R1100SBX Shut Up and Ride |
John B. 03 R1100S Prep(wife's), 02 Futura, 92 907ie, 89 Transalp, 87 R80/100, 82 Morini 3.5 sport, 76 R90/S, 73 R75/5 90 535im & 95 525i Touring 65, 66 Alfa Romeos |
Just a comment here: it looks to me like, if you didn't have this sort of stand, you could strap the front tire/rim down TIGHT to the floor and use an engine hoist to lift nylon strap run around both cylinder heads to lift the whole rear end off the ground. Only problem is, you'd have to pull the gas tank first before hoisting.
Still, you'd be able to do that level of work without the specialized engine mount. Any idea how different this would be on an R1150R/Rockster? |
Bikepaintr:
I'm still of the opinion that TIG is better than MIG for almost anything. As with most things in life, experience counts; the specalized frame builder I know, wasco frame service (and he's a true magician; built frames for most of the OEM race teams at one time or another, if you saw the HRC honda 'CB900F' superbikes of the freddie era, some of 'em came from his shop) exclusively uses TIG. Of course, the price of admission is much higher; as with everything in life you get what you pay for. A cheap MIG is about $300.00...a 'cheap' TIG (if you can call it that) is about $2000.00 and goes up fast from there; I personally want a miller 2500 'square wave' TIG to do all materials; stainless, aluminum, ti, etc.....but once up to speed, you can write your name on a piece of sheetmetal with TIG...there's nothing else like it, and all the SERIOUS hot-rodders I know have a TIG machine stashed somewhere in the shop.
Barback King
Proof
Great stuff repoe, this is what makes this INFORMATION forum worth while.
Furthurmore it is PROOF that the mark is what it's always been (at least in the boxer's case), something that you can ride, work on, and ride some more...I'm lovin' it. It's like ISDT stuff...why this must be why those Hollywood Brit Boyz rode boxers around the word "Long something'er other"....except don't weld the ABS brakelines and don't get gas in yer eye....
R11S CNC BARBACKS |
Except you have to rip the whole frikkin' bike apart to do clutch work; you can't do this on the side of the trail with the tools in your fannypack....
Barback King
mmm...Maybe!....
R11S CNC BARBACKS |
