jgrm1's Avatar
Safe Minimum Tire Tread Depth?
Guys,
What is the safe minimum limit for tire tread depth to prevent hydroplaning? At what tread depth should a motorcycle tire be replaced?
I've seen it vary from our owner's manual, which states 2.5/32" (2mm) on the front and 3.8/32" (3mm) on the rear to as little as 1/32" (0.8mm). This difference in tread depth can translate into a lot of miles gained or lost.
What is the best balance between road safety and tire life?
Thanks,
Jeff
BMW: 2024 R1250RS, 2016 R1200RS (For Sale), 2000 R1100S, 1975 R90S
Ducati: 2008 S2R1000, 1998 900 SS/FE
Norton: 1974 Commando 850
Triumph: 2020 Speed Triple, 1976 T140V Bonneville, 1973 TR7RV Tiger, 1971 T120R Bonneville, 1970 TR6C Trophy
Old 03-29-2005, 03:17 AM
BMW Atlanta's Avatar
Send a message via AIM to BMW Atlanta Send a message via Yahoo to BMW Atlanta
There should be wear bars on the center of the tires tread. It will be a hump of rubber in one of the tread grooves, when its flush with the rest of the tread, its definitely time to replace. However err on the side of caution. Its always safer to have a new tire even if yours is only %50 used.
Bobby
BMW Ducati & Husqvarna of Atlanta
06 HP2 SM, Akra Ti, RapidBike3,
Old 03-29-2005, 03:49 AM
I'm thinking wear bars are 2/32" but could vary by tire type. For me, some tires will have other issues to warrent changing. After wrestling all these years, I bought a Harbor Freight changer (thanks for the push, Joe), makes it much easier.
I still have memories of a Norton rally 25 years ago of a guy sorting through the dismounts for something better than he had on. ("I'm on a low budget"). But at least he was there.
Jim
down to jap bikes that run and a dead Norton
Old 03-29-2005, 04:02 AM
Does anyone know the website for the Harbor Freight changer?
Old 03-31-2005, 11:15 PM
mullerjd's Avatar
www.harborfreight.com
Changer
05 BMW R1100S BCR, 87 BMW K75C, 69 BMW R60US, 63 R69S sidecar project, 02 Suz SV650S, 01 Suz SV650S, 00 Suz SV650 naked, 01 Suz TLR fighter, 05 Suz DL650, 98 KTM 380 MXC
Old 04-01-2005, 03:47 AM
Skippy's Avatar
I thought bikes didn't hydroplane at all or at least verry little.Modern tires on motorcycles(esspecialy rears) actualy don't have that much thread to begin with.I think the rubber compound(100% silica best for rain) is the biggest influence on wet weather riding.So therefor I try not to ride with tyre's older then a year cause after a longer period the rubber tends to loose grip(altough normally you wear true a couple of tires during a year so this isn't a problem for me)The contact patch is so small that this is rarely a problem.For the front I normaly look att the wear bars but with the rear I probably ride a bit longer in case of emergency untill the point where there's almost no thread left(not in the winterseason though).
Look at this rear for instance(mez6) almost no thread in the center of the rear the front has to ride the road dry for the rear wich is the case with most modern tires.
Meet you at the bitter end...
'09 Aprilia Scarabeo 250 i.e.
Old 04-01-2005, 03:59 AM
steve abella's Avatar
I think that we all go through this question but with differnet tolerances I am always suprised how much nicer the bike rides with new tires especially if the front has any cup in it
,93 LT Hacked
98 RT
02 S ohlins/laser
06 HP2
84 GS/KTM
Old 04-01-2005, 05:47 AM
