Vanderlinde replacement part availability?
Hi,
Does anyone know if where you can get in the US replacement parts for a Vanderlinde exhaust. I need to replace the two rubber "bushings / grommets" that hold the cans in place under the seat. When I installed my pipe, I must not installed it square to the bushing, they got tweaked a bit, and I think the cans vibrate at speed because of it. I get a nasty vibration at the pillon seat over 80. Had my tires balanced numersous times, but it does not help much. That said, is there even a distributor in the US anymore for Vanderlinde? Thanks in advance, Robert M.
moved from Chicago to Charlotte so I could use the sides of my tires ![]() |
Biggest Member
Robert,
AFAIK, there is no longer a distributor in the US for Vanderlinde. at one time one of the Toronto area dealers was the sole North American supplier. unfortunately, i cannot recall which dealer this was or if they still carry vanderlinde stuff. you may have better results going straight to the Manufacturer. Etienne Vanderlinde is very pleasant to deal with, although followthrough can be somewhat problematic. have you checked whether the stock BMW grommet will work? Good luck! Lance |
Lance,
Thanks for the link. Weird, they sold quite a few of the pipes here, and now no parts available locally. As for trying the BMW parts, not a bad suggestion, I will look into that. Regards, Robert
Living on borrowed time!
use the OEM bmw part...I did.
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
These were missing when I bought a used pipe, and I used the BMW parts with no problems.
99R1100S
Dive the worlds underwater museums at www.shipwreckcentral.com |
I was wondering if I could use the BMW ones, thanks for the idea!!!
Robert
Just wanted to let you guys know that I wrote Van der linde, and they sent out some grommets and I got them in less than 10 days from South Africa!!!
I can't get my local postman to get packages across town in Chicago that fast. Anyway, I heard via email from Mr. van der Linde himself, and he took care of it. I really think they handled this great, and I know when they come back to the States, I will consider their pipes first. Hopefully they are working one up for the 1200s. Robert
No Info on (t)his member
It could only make them look bettah!
:) jeff |
Thread Tools | |
Rate This Thread | |
