Send a message via Yahoo to jtwolf
Lightbulb Anything Else I Should Know???
I just bought a 2001 R1100SLA and it's time for its 12,000 mile interval. I read the manual and read "Valve Adjustment for Dummies." It certainly seems like a much simpler operation than the GSX1100G and the VFR800 I already own.
Are there any surprises in there once I pop the lids off the jugs? Or is it all as straight-forward as it seems?
Old 06-15-2006, 06:50 AM
Flatbutt1's Avatar
very straight forward.
big blue tricycle
stare down the darkness and watch it fade
Old 06-15-2006, 07:03 AM
Yep, it'll take you all of 20 mins.
Old 06-15-2006, 07:12 AM
SCOTTinNJ's Avatar
at 12k you should do more than just the valves. check the book. fluids need to go.
Old 06-15-2006, 09:12 AM
Barback King
Rapid Dog's Avatar
welcome new dude, ditto what the boys here said, but I'd allow a nice Sunday afternoon so you can take your time, dropall the fluids,
get your oil filter and crush washers from the dealer
expect to do an airfilter service too.
R11S CNC BARBACKS
Old 06-15-2006, 09:50 AM
...no really, I was just going to drain out the oil into a coffee can, rinse out the filter with kerosene, and reuse them both. Hydraulics? Never change them until they look like root beer. Air filter? Nah, breathes better without it.
C'mon....
Old 06-15-2006, 10:02 AM
Barback King
Rapid Dog's Avatar
...a sense of humor! Good, we need more qwikwits around here ...
R11S CNC BARBACKS
Old 06-15-2006, 10:13 AM
ninermatt's Avatar
What all does the 12k involve?
Old 06-15-2006, 11:26 AM
Be careful putting the valve covers back on. Run a finger up the sparkplug hole and make sure you don't have the inner valve cover gasket (donut shaped) crooked.
I try to use mine at least one or two valve adjustments, but the more oil you get on the inner gasket the harder it gets and more likely it is too leak.
Use two feeler gauges per set of valves (one of each intake OR exhaust valves). Try and get the "feel" the same.
After a good valve adjustment, ride the bike about 30 miles and then do a very careful throttle synch.
I suggest Autolite 3923 sparkplugs changed every spring along with all the fluids and filters in your bike.
Old 06-15-2006, 11:31 AM
Thumbs up See...
...THAT's what I'm talkin' about! CONSTRUCTIVE help.
Old 06-15-2006, 11:33 AM
Barback King
Rapid Dog's Avatar
...check yer manual...
Basically like was said, set valves, air filter service (or replace), drop all the fluids (good time to go synth), oil filter, brake bleed is good too....and a general once over...
R11S CNC BARBACKS
Edministrator
Steve Carlton's Avatar
There's annual services as well, which are basically brake and clutch fluids I believe. Some say don't worry about them until the fluid starts to get dark. If you have ABS, you might want to let a dealer flush the brake fluid. Also, if you have the original battery, I'd replace it while you're at it.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 06-15-2006, 11:37 AM
JTWolf - answered your PM.
Let me know when you're coming up and I'll bring my TwinMax and I'll show you how to sync the throttle bodies.
I do the equivalent of a 12K service every spring, all the oils, filters, etc.
What's the saying, "an ounce of prevention is worth a pound of cure" or something like that. Besides, it's a good time to give the bike a once over before the riding season.
Old 06-15-2006, 11:43 AM
