MrK MrK is offline
Kraut Burner
MrK's Avatar
What is the best way Need Help.
Hey working on taking out the rear suspension and need to know if it is easier to loosen up the exhuast in the front and try to slide the exhuast forward to get the suspension bolt out, or should I take the mufflers and tail header off. I don't have a cat.
'06 BMW GS
'04 BMW R1100SBCR 46/300
Old 02-11-2007, 04:52 PM
unsafe at any speed
wswartzwel's Avatar
Getting the mufflers off the rear frame can be work...
When you say rear suspension do you mean swing arm and moving parts.. or just the shock?
If you mean the entire suspension system I like to pull the rear subframe with mufflers as a unit...
then you have easy access to whatever you want to work on.
heres a cat if you need one.
Bill Swartzwelder
Old 02-11-2007, 05:02 PM
Uh....who me?
Bob Hancock's Avatar
OK....I have to ask
So...Bill....you decided to go for a swim today and jumping off the diving board you realized in mid air that the pool was empty. Right?
ps....love the cat!
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 02-11-2007, 05:14 PM
unsafe at any speed
wswartzwel's Avatar
Actually... I have been fighting a chronic Prostate infection since before I did Flattbutts transmission... Oct-Nov.. 2006..... I have been on Cipro for many weeks and finally got the doctor to change my meds due to the bad depression it gave me... I have been miserable for 5 months and everytime I ride I get sick again. Oh and today I came down with the flu as well... TMI but I am kinda nutty anyway... I heard Laughter is the best medicine so I am trying that out...
Bill Swartzwelder
Old 02-11-2007, 05:21 PM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Laugh till it hurts!
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 02-11-2007, 05:22 PM
Uh....who me?
Wow....sorry to hear all that. I hope you laugh long and get well soon! Your post was sure funny to me. Is this something we can blame on flattbutt?
Bob Hancock
Old 02-11-2007, 05:29 PM
unsafe at any speed
wswartzwel's Avatar
Nope..I had it before he arrived.....I took a nasty hit from the front part of my seat, directly to the prostate while Mountain bike riding in the mountains... Infection went away once, came back after Falling leaf rally, then went away again, but I have been riding my KTM a lot and it has aggravated the healing process
Bill Swartzwelder
Old 02-11-2007, 05:33 PM
MrK MrK is offline
Kraut Burner
MrK's Avatar
Ok Ok enough jokes I need some good advice here, I just need to get the rear shock out and the bolt won't clear so I need to drop the exhaust. I just don't want to start removing stuff that I don't need to. Is it easier to slide the exhuast forward or remove the rear mufflers?
I don't have a cat and I don't want one!!!
'06 BMW GS
Old 02-11-2007, 05:34 PM
unsafe at any speed
wswartzwel's Avatar
Getting the mufflers off the rubber hangers can be hard. Getting the headers off the bike also often yields twisted off bolts.
Which is why I prefer to take the subframe off with the mufflers... only 4 bolts!!!
Try loosening the cat eliminator pipe, and removing the rear (lower) subframe bolts... should get you enough room to get the shock bolt out
Bill Swartzwelder
Old 02-11-2007, 05:45 PM
MrK MrK is offline
Kraut Burner
MrK's Avatar
Got it thanks a bunch.
'06 BMW GS
Old 02-11-2007, 06:04 PM
Man it's flat out here!
R111S's Avatar
We'll pray for you some more Bill...God Speed!
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 02-12-2007, 07:17 PM
Dbltailexit's Avatar
wswartzwel - thanks for the humor and the pictures- i was planning on taking the engine out of frame to weld broken rear bracket but now i see taking frame off engine is the way to think of it. inspiration without the persperation. - get well, get strong - ride dirt keeps my sanity also.
Lotus 7 replica, 4 wheeled motorcycle.
Old 02-12-2007, 07:38 PM
unsafe at any speed
wswartzwel's Avatar
Thanks for the kind words guys....
dbltailexit...Which brackets are you welding?
I welded the top 2 tabs with the bike still assembled less the plastic, and added a couple gussets...
Bill Swartzwelder
Old 02-12-2007, 07:48 PM
yes the two top, any other tricks.
my welder had asked me to get it so the material would be horizontal for best results. he's tig and mig and he tells me aluminum is harder to weld then stainless. i'm just a arc welder on farm equipment hacker. thanks
Old 02-12-2007, 09:53 PM
unsafe at any speed
wswartzwel's Avatar
Yes aluminum requires tedious cleaning... Any paint or foreign material and it just splatters instead of flowing together. Using a tig is best and should not require horizontal placement of items to be welded... Mig makes a mess and works better laying flat.. Removing the frame and thorough cleaning/sanding would be the best way.. Since this was my bike I opted for the shortcut. 15K since then, and it is still holding.
Bill Swartzwelder
Old 02-13-2007, 06:15 AM
Living on borrowed time!
JonyRR's Avatar
to pull the mufflers
take off whatever is bolted to the plate bracket for the muffs
fab up a steel plate that bolts up where you took off the other stuff.
now fab a connector (i just drilled a hole in the plate I made) and hook up a slide hammer to it.
2 pulls of the slide weight and the muffler assembly is in your hot little hands.
easy, no-sweat method of doing a normally b!tch of a job.
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 02-13-2007, 01:56 PM
unsafe at any speed
wswartzwel's Avatar
Where is the touratech clutch install thread at sir Jony?? We are waiting...
Bill Swartzwelder
Old 02-13-2007, 02:05 PM
