jaylow's Avatar
Send a message via Yahoo to jaylow
Restarting a warm engine
Hey folks, I wanted to bounce something off the collective knowledge of the forum.
I have an '01 R11SLA, and when I start it up from cold, it starts right up, goes to high idle when the "choke" is pulled, etc. Quiet as a...well, quiet for a BMW Oilhead. However, if I let the bike warm up or ride it for a ways, turn it off then restart, I get a knock-knock-knock during the first seconds after it starts--before it quiets down into a regular idle. The bike has 38k on it, but I have records of "as scheduled" dealer maintaince back to new from the previous owner. Oil level is correct, I check it religiously.
Having owned some older Ford products, knock-knock-knock on startup meant you had a rod bearing that wasn't long for this world.
Am I being oversensitive?
Old 08-03-2007, 09:49 PM
ExarKunONe's Avatar
Send a message via AIM to ExarKunONe Send a message via Skype™ to ExarKunONe
Mine does that sometimes.
Old 08-04-2007, 12:59 AM
Sounds like the chain tensioner. With the oil hot it takes a second or two for the pressure to build back up and tension the cam chain. There is a mod somewhere in the forum where the R1100S chain tensioner can be replaced with the R1200. I wouldn't be concerned, just another idiosyncrasy of the R1100s, if your really concerned try a oil change, perhaps a slightly different grade.
1993 R100GS PD
2003 R1150R Edition 80
2003 R1100S BCR
Wanted - 1939 R50 TT or RS54 Rennsport
Old 08-04-2007, 03:48 AM
jaylow's Avatar
Thanks guys, just found the tensioner thread. I'll give it a go.
Old 08-04-2007, 08:44 AM
