oldbiker's Avatar
why only 5amp circuit on accessory socket
Plugged in my Gerbing jacket and keep blowing the circuit breaker. I'm using a Gerbing Heat Troller. When increasing the temp i blow the circuit. What the F@#$. I have tried the controller and jacket in three other bikes, non BMW. Works fine. Apperently Gerbing's amp rating is 7.4amp and the BMW R1200S accessory socket is only 5amp. I suppose BMW wants me to use only their brand heated jackets! I will call the dealer tomorrow and see what kind of bull**** they hand me. has anyone else had this problem. my only option is to run directly off the battery with a 10 amp fuse? Its getting cold here in Wi and sure would like to use my heated jacket.
Old 09-16-2007, 08:15 AM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
....just put a 10amp fuse inn... the wires are a little thinner, but still not thin enough to worry... see whether it still blows the fuse and go from there...
Cold?... yeah, it is getting cooler here as well, temperatures in the mountains are down into the 70's and the desert only gets over 105 occasionally now
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 09-16-2007, 08:21 AM
tjs tjs is offline
5 amp circuit
The only way to run your Gerbing is to go straight to the battery with your 10amp fuse. Can-bus accessory socket won't handle anything that draws over 5 amps. Had to do the same with my R12S. tjs
Old 09-16-2007, 08:35 AM
Right-O, tjs. When you run the line from the battery remember to put that inline fuse in a place that it will accessible by just removing the seat. Unless you need to practice taking the tupperware on and off. I'll double plastic bag the end of the wire during the summer and tuck it away.
Trex
Old 09-16-2007, 08:53 AM
Uh....who me?
Bob Hancock's Avatar
Had to do the same thing on my R12S, but the plug worked fine on the R12GS I had which is also CanBus. Don't understand that.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 09-16-2007, 09:14 AM
roger albert's Avatar
Either way, it's a big draw on the bus. It should really be ran back to the battery.
No need to be hissy. I don't think the dealer will give you any bull, just a reality check.
It is the can bus, as implemented on that bike. Not just a bunch of dumb wires as on the other bikes you tried it on. Of course, sometimes dumb wires are not only good enough, but better. Guess this is one of those. Technology improves a lot, but sometimes there's a step back thrown in for good measure. Hang in there. I wish it worked like it does on the GS too.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 09-16-2007, 09:39 AM
Living on borrowed time!
JonyRR's Avatar
You really don't want to pull a continious 5 amps thru a circut designed to blow a fuze at 5 amps. Wire gauge just isn't up to this.
Straight to the battery, mate!
I just wired a gerbing's plug on a K1200R-S and it was simple...right up until I had to pull all the $%&Iing plastic off....just like my 1100S....they DON'T make these to work on anymore....
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 09-16-2007, 10:00 AM
oldbiker's Avatar
what good is the factory accessory plug if you can't use heated jacket? I do have a optional Gerbing straight to the battery plug with a 10amp fuse that i have used in the past on other bikes, that didin't have a accessory outlet. I just don't understand why BMW wouldn't have put in larger amp breaker then a 5. Correct me if I'm wrong,, on the r1200s there are NO fuses just breakers that are reset when you turn off and on the ignition switch?
Old 09-16-2007, 12:18 PM
You have a great point but it doesn't change the facts. BMW has made the socket unusable for electric clothing (probably because the ZFE can't withstand that sort of current on a long-term basis) so you need to go directly to the battery. Simple as that. The acc socket is for charging the battery (if you get the voodoo right) and not much else.
Hard-wire a pigtail to the battery, 15A or 20A fuse, and you're golden.
Anton Largiader
Charlottesville, VA
Old 09-16-2007, 02:47 PM
Uh....who me?
[QUOTE=AntonLargiader;3482447] The acc socket is for charging the battery (if you get the voodoo right) and not much else.QUOTE] And of course the easiest way to get the voodoo right is just wire your Battery Tender connection directly to the battery while you're in there wiring your Gerbing lead, which is what I did, rather than spend a billion dollars on a special tender that talks to Mr. CanBus. Executive Summary: The acc socket ain't worth squat.
Bob Hancock
Old 09-16-2007, 02:58 PM
oldbiker's Avatar
Not even sure if you can use the socket for charging.. Owners manual say's the socket becomes inactive 15 minutes afer igniton is turned off. Well i quess I'm wiring up directly to the battery. thanks for the answers
Old 09-16-2007, 03:13 PM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Yep,
Best bet for charging is to wire a pigtail direct to the battery as BMWAtlanta suggested a year ago.
For all practical purposes the socket is useless.
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 09-16-2007, 03:44 PM
President - Okie Chapter
BMathison's Avatar
I wouldn't say it is completely useless, I still use my acc socket for radar detector or XM, but would take anything else back to the battery.
___________________________
R1200s - Yellow, of course
Two Wheel Oklahoma - Go watch it!
Old 09-18-2007, 08:19 PM
What I did was: snipped the OEM wire, ran that to a relay so the relay is on /off with ignition. The relay is wired and fused to B+ and to the socket. I like the switched power outlet. Also an aux light is wired to the relay through a switch.
tom rides and runs but 4 wheels no more;
added a '94 DR350SE goes to Mendocino, F650Dakar captain america sees Baja
R12S Red and Silver for cruising, the very first one was Honda C-90 way back when
Old 09-18-2007, 08:56 PM
Snob Pirate
geothepencil's Avatar
Nobody told Mary's S that it couldn't run a BMW heated vest. But we also have the fused pigtail to run Gerbings attached to the battery.
geo
"She sips nitro... with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the ***** is born to run!" Barry, MFP mechanic
BMW/Yamaha/Suzuki
I've been ionized, but I'm OK now.
Old 09-19-2007, 09:24 AM
And I thought I was the only one with this problem. I am considering cutting the leads to the accessory socket and attaching it (fused of course) directly to the battery. I hate not having a fuse box.
Old 09-26-2007, 06:38 PM
Towjam's Avatar
BMW makes a battery tender that is canbus compatible and can connect through the socket. However, there is a trick to using it: You have to turn on the bike's ignition, plug the tender into the accessory socket - then turn off the ignition. The tender "communicates" with the canbus system - thus keeping the socket "live". Works like a champ. Unfortunately, it's not cheap (over $100) and as far as I know, it's the only canbus charger currently available.
Cheers!
Towjam
...more BMWs, Buells, Harleys and Hondas than you can shake a stick at!
Old 09-26-2007, 07:55 PM
Towjam's Avatar
The 5 amp "limit" is a software-imposed limit that BMW could easily upgrade with a software update. In fact, the 1200RT's accessory socket is rated at 10 amps - I had no problems running my 10 amp air pump off of it. The same air pump would not work on my ST or 1200GS without the canbus shutting down the socket. Makes no sense whatsoever.
Cheers!
Towjam
Old 09-26-2007, 08:00 PM
Cyclone Jack
hawkeyejohn14's Avatar
Another reason to enjoy my R11S Although it does sound like an easy fix, still for the money it shouldn't be needed.
jc
2004 R1100SA Pacific Blue
Old 09-26-2007, 08:36 PM
