R1200s mmmm!
Originally Posted by Black12s View Post
I believe you use the two jam nuts that are located just above the lower shock mounting point to adjust shock length... aka ride height? That way you don't have to compromise preload for seat height.
Im sure i read on here as stock its on lowest setting already for ride height, as i was going to lower mine some as its just a bit to high at times for me!
and was going to lower preload some but not sure if should even try now with this plastic ring!
Lee
R1200s Red/silver, ABS, Ohlins, Sports wheels, heated grips. K1200r - R.I.P.
Old 01-30-2008, 06:13 AM
roger albert's Avatar
MOst of the stockers I've seen, were indeed already at minimum height at delivered. The one exception might have been futzed with, so who knows.
The preload with plastic is still doable, but it works best with the rear end unloaded and believe it or not, on a cold day (less flexible plastic) with a cold bike and motor.
Use the factory 3 prong wrench, not a conventional/generic single hook wrench.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 01-30-2008, 06:24 AM
R1200s mmmm!
Cool, i think i have the 3 pronged one i know have to one to adjust ride height, will try it before warranty is up i think in may so atleast if it breaks can claim it then i hope! im sure in owners manual there is no mention of unloading the back or anything so they cant say you did it wrong!!
Lee
Old 01-30-2008, 07:03 AM
Ride height comes preset from the factory at the lowest setting.
Mal Glanz
Ft. Lauderdale, FL
'12 ZX-14R
'09 CBR1000RR (w/pegs & bars, now my touring bike)
'10 S1000RR & '07 R1200S (gone, but loved 'em)
Old 01-30-2008, 07:26 AM
Indeed, unloading the shock is the answer, as it worked for me. The 3 prong wrench won't matter, because the plastic ring will still "jump" the thread. But this is only a problem when INCREASING preload.
Mal Glanz
Ft. Lauderdale, FL
'12 ZX-14R
Old 01-30-2008, 07:31 AM
The early bikes came with a 2-pronger. I posted about this when I picked up the correct 3-prong from my dealer.
Jon Maddux
08 M3/4 | 07 R1200S | 07 R1200RT | 01 M coupe
Old 01-30-2008, 07:50 AM
